Link Group Buy Closing this Friday...
Postby mister2 » Sun Jan 21, 2007 11:18 pm
Traffic to the group buy thread appears to have stalled, so just to keep people aware if they're after a Link ECU now is the time!
Basically the deal is that you get free shipping and either a free air temp sensor (required in most installations, $120) or a free boost control solenoid ($150) with every ECU purchased.
Details here
Mods feel free to moderate this, I am just trying to make sure people do not miss out on this deal!
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Re: Link Group Buy Closing this Friday...
Postby l1ttle_d3vil » Tue Jan 23, 2007 8:42 pm
mister2 wrote:Basically the deal is that you get free shipping and either a free air temp sensor (required in most installations, $120) or a free boost control solenoid ($150) with every ECU purchased.
is the standard air temp sensor fitted on the ae86 4age inlet manifolds suitable for this? or are your sensors "special"? :P
Postby matt dunn » Tue Jan 23, 2007 8:53 pm
Not sure i'm 100% correct, But the AE86 Inlet temp sensor I tried would not work.
I had to buy a special Bosch Air temp Sensor.
Matt
Postby l1ttle_d3vil » Tue Jan 23, 2007 10:36 pm
how old was the link though? is it possible it wasn't compatible with the link if it was an older version? my understanding is some sensors aren't compatible with the older links, but this is not as common with new links.
mister2
The only real thing which can ad to the cost is extra sensors & changing things like sensors,ignitors,coils etc for units compatible with the Link ecu although this is being less common. The only sensors we generally change are Throttle position sensors, from a switch type to a variable rsistro scaling type, mainly so you get a percentage throttle opening rather than open or closed. The only extra sensor we sometimes fit is an inlet air temperature sender, mainly for turbo stuff,
Postby matt dunn » Tue Jan 23, 2007 11:33 pm
l1ttle_d3vil wrote:how old was the link though? is it possible it wasn't compatible with the link if it was an older version? my understanding is some sensors aren't compatible with the older links, but this is not as common with new links.
Was an older version but a Linkplus, so not too old.
mister2
That's me. Had to fit that.
I dont know, the new stuff may use the Toyota Temp Sensor,
Guess we will have to wait for mister2 to answer that one.
Postby mister2 » Wed Jan 24, 2007 12:30 am
Basically... it depends :D
We sell NA and Turbo sensors - there is a difference. If your engine is NA and you've turbo'd it (ie, like all 4AGTE's out there) you really want to go to a Turbo sensor - they are faster responding, like in under a second compared to 10 sec's for an NA one, which is required for boosted applications where the temps change rapidly.
HOWEVER, you can configure a (G2/G3) Link to accept any sensor. All you need to do is stick it in a jug with a thermometer and measure the resistance as the temp rises (say every 10* from 10* to 100*), then enter this into the table in PCLink.
We generally are selling inlet air temp sensors with ECU's because the majority of people are putting them on air flow metered cars, where the air temp sensor is built into the AFM which they then remove.
Hope that helps.
Nick
www.nzefi.com
mister2
Postby mister2 » Thu Jan 25, 2007 12:56 pm
Tomorrow is the last day fellas!
Nick
www.nzefi.com
mister2
Postby Adydas » Thu Jan 25, 2007 2:12 pm
For intrest sake, how much responce have you had?
Adydas
Postby Distrb » Thu Jan 25, 2007 4:07 pm
Adydas wrote:For intrest sake, how much responce have you had?
purchasers have been named in the group buy thread
Distrb
Regular Poster
Postby mister2 » Fri Jan 26, 2007 8:51 am
Going.... going.....................
www.nzefi.com
mister2
Postby mister2 » Fri Jan 26, 2007 8:52 am
www.nzefi.com
mister2
Postby mister2 » Sat Jan 27, 2007 9:08 am
Closed. To all those who bought one, I'll start sending them on monday.
Cheers!
Nick
www.nzefi.com
mister2
Users browsing this forum: Bing [Bot] and 4 guests
