Turbo upgrades
Turbo upgrades
Postby gazza_jay » Sun Jan 21, 2007 1:03 pm
I know theirs a few starly owners out their so I guess someone could help, Im luking 2 get a 92 staret and the turb feels a bit tired so I was wondering what is a good upgrade from the standard turbo, and a rough estimate of how much they cost..
gazza_jay
Postby IH8TEC » Sun Jan 21, 2007 1:26 pm
www.starletcentral.co.nz is your best friend :D just make sure when you register, to have a search through the forum, because it's been covered ALOT on there.
Postby flygt4 » Sun Jan 21, 2007 2:12 pm
apparently tdo4 is perfect for them
flygt4
Postby slighty_looney » Sun Jan 21, 2007 2:30 pm
yea td04 off a wrx or gsr would be a good size for a starlet :P
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby Dell'Orto » Sun Jan 21, 2007 3:31 pm
I'm sure a GT35/40 would go nicely and spool well on one :lol:
If you're up to spending some coin on it, a Garret GT20 would be quite nice.
Postby loose_unit » Mon Jan 22, 2007 6:57 pm
T3's go well on them :D. Im biased though coz thats whats on mine.
You could either highflow the stock unit, which is a mild upgrade. Or if you want to put a bigger one on there there are a few that work pretty well. TD04L, VF10, T25, smaller T3's, and probably some other medium sized turbos that will probably do the trick.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby gazza_jay » Mon Jan 22, 2007 10:04 pm
cheers people Ill do a bit more research, its put me on the right track
gazza_jay
Postby dotdog » Wed Jan 24, 2007 7:10 am
Go the td04 off a wrx, dont bother with one off a GSR. The wrx one is bigger and flows more than the gsr one
dotdog
Postby loose_unit » Wed Jan 24, 2007 11:33 am
Yeh the wrx one is the one to go for. Even tho it does have a stupid triangle flange :P
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby gazza_jay » Wed Jan 24, 2007 6:31 pm
o yup ok then, now I gotta look 4 1 and price out 1, whats a good size intercooler,
gazza_jay
Postby Elmendorf » Wed Jan 24, 2007 6:49 pm
Early VR4 one work well, better flow than the later models.
Elmendorf
Postby loose_unit » Wed Jan 24, 2007 7:00 pm
Early Evo 1 & 2 coolers will also fit behind the stock bumper.
You dont want to go anything more than 260mm tall and around 450 ish long. Any longer and the piping starts to get tricky.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby bluemaumau » Wed Jan 24, 2007 9:16 pm
Harlet wrote:Early VR4 one work well, better flow than the later models.
is that a 100% true?
p.s im not be being smart i just cant figure out how the older one can be better. mitsubishi :roll:
Postby loose_unit » Wed Jan 24, 2007 10:46 pm
Later model ones have tanks top and bottom, and the design isnt as front mount friendly for starlets as the early vr4 ones due to the in/out pipe placement.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby Loudtoy » Sat Jan 27, 2007 7:00 pm
Tdo4l off a gsr should be fine. If you can find the stock cooler off a twin turbo supra use that. They actually have a decent area plus core size. Might have to watch how your exhaust is done as i had problems with boost creep (like 12-18psi creep) when i put the td04 on, sorted it by porting the internal gate out. I got the whole setup on there just running 8psi for $500 but did all the work bar cooler pipe welding and manifold myself. May have helped that i had mates who did the fabrication work for the mani for a doz or 3 tho and another mate who was selling his gsr gear with the cooler cheap as he was upgrading :)
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby JIZRAG » Thu Feb 08, 2007 7:23 pm
TD04 off 2000 WRX are the go, If you want proof ill take ya for a skid in mine, just ask PRYMAL for some reassurance :P
EF9 Civic - 1:16.9 Manfield
JIZRAG
Postby Dell'Orto » Thu Feb 08, 2007 7:50 pm
Is that you Tony? Nice username :P
Postby JIZRAG » Thu Feb 08, 2007 10:01 pm
Yea sure is, one day ill even get the plate to go with the username lol.
JIZRAG
Postby MR2SIK » Thu Feb 08, 2007 11:26 pm
my mate had a ct12? off a supra i think on hers, went quite nicely, absolutley dicked standard starlet gt's plus it was a straight bolt on job.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby loose_unit » Fri Feb 09, 2007 6:52 pm
CT12's off supras are a different flange alltogether. The CT12's that fit are off some diesels and a few other cars. But theyre by no means an upgrade, in fact the compressor housing is stightly smaller on them.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Return to Palmerston North / Central North Island Region
