diff ratios MX83
diff ratios MX83
Postby big_boy » Fri Jan 26, 2007 9:26 am
douse any one know the diff ratio of a MX83 cressida with a 5M & manual as we are looking at putting a LSD that we have in it except its a MA70 supra 7M auto diff thats ither 4.1-1 or 4.2-1 i cant rembour but just want to know how much higher this would make the gearing
for sale EE90
big_boy
Postby spencer » Fri Jan 26, 2007 10:31 am
a manual 5m mx83??? there all 7m and a340e. The supra has a different diff housing to cressidas, mark 2's etc so unless you mod the mounting points your going to have to swap the internals over anyway, so may aswell swap the lsd onto your ratio
ms63 crown
spencer
Postby big_boy » Fri Jan 26, 2007 11:04 am
well its a 5M cresda diff any way i thort it was a MX83 (its at work il check when its home) tho well any way will the centre of the supra one bolt up to the cresidas crown wheel ect aslong as there both F series
for sale EE90
big_boy
Postby spencer » Fri Jan 26, 2007 11:07 am
ok it aint a mx83 if its a F code diff all the m engine x8's are G code diff. More likely mx73 and a manual one of those is rare! If there both F code they internals will swap over you need the lsd half-shafts or shorten you non lsd ones
ms63 crown
spencer
