TRD air filter for Caldina GT-T
Postby Mark H » Fri Jan 26, 2007 5:08 pm
Hi all
I've just purchased a 2001 Caldina GT-T (pics to come soon hopefully!).
I'm making a few minor mods, within the boundaries of the car's signature class warranty. I've fitted 17" alloys and Dunlop Direzzas, and have also had a new 2.5" exhaust system and installed.
I'm keen to fit a TRD air filter, but am keen to hear from anyone who has one of these (or something similar):
-What sort of difference do they make to performance? (I've had a dig on the internet and found a claimed increase in power of 5hp, which seems quite decent for something as simple as an air filter...I guess it's all about the engine's ability to breath...).
-Generally, how long do they last compared to normal $50'ish air filters? I know this will depend on the distance and conditions one travels in, but I'm interested to know whether they typically last longer than an OEM filter.
Mark.
Mark H
Postby flygt4 » Fri Jan 26, 2007 5:12 pm
most aftermarket filters are cleanable. they last a lot longer before a shitty paper ones before they are filled full of crap anyway.
yes , it will make a slight difference, and youll get more whooshy sucky noises. dont expect it to be hugely noticeable tho, maybe just a slight improvement in pickup. combined with the exhaust you should notice it feeling a bit better than it was standard.
flygt4
Postby aesc » Fri Jan 26, 2007 6:56 pm
The best and cheapest way to get good gains from the intake is any type of aftermarket filter and run some ducting to the factory airbox from a cold air source.
I wouldnt bother with a TRD filter myself, they are still a paper filter so cant be cleaned. K&N are the way to go
EX AE101 owner
2013 Ford Focus ST
aesc
Postby Mr Revhead » Fri Jan 26, 2007 6:58 pm
actually they are not paper, they are fabric and do last longer.
how ever hard to say how long as it depends totally on the conditions u drive in.
Postby vvega » Fri Jan 26, 2007 7:44 pm
Mr Revhead wrote:actually they are not paper, they are fabric and do last longer.
e
for th price of a paper filter....15 bucks
you can just change them monthly......
its also proven that teh paper elements are the best filtration you can get
......till they get blocked
my 5 cents anyway :d
v
vvega
Air filter for Caldina GT-T
Postby Mark H » Fri Jan 26, 2007 8:19 pm
Thanks for the advice. I'd undoubtedly consider other aftermarket air filters such as K & N, especially if they are washable. However, I have to use Toyota approved parts to keep my warranty valid, hence the reference to TRD airfilters.
Mark.
Mark H
Postby snwtoy » Fri Jan 26, 2007 10:30 pm
e
v
Filtration between a paper element, and a properly cleaned+oiled k+n is pretty marginal I thought? And with the K+N you get better flow surely?
snwtoy
Postby Lloyd » Fri Jan 26, 2007 10:35 pm
Less filtration = less restriction = better flow ;)
Hence K&N should have better flow than paper
Look at a lot of K&N filters and you can just about see through them. Run one for a few thousand kms and have a look at the intake piping after it and see what you reckon. Have used a few cheaper K&N style oiled filters and have had varied results
Postby vvega » Sat Jan 27, 2007 1:17 am
e
v
you would cry if you saw how much atually gets though a k&n
really the only thing that sports filters stop getting into your engine is birds small children and the ocasional skank that gets to close :d
vvega
