Trying to take airflow meter of and run straight k&N FIL
Postby antonio » Mon Jan 29, 2007 11:07 pm
IM TRYING TO TAKE OUT THE AIR FLOW METER AND RUN STRAIGHT KN FILTER CAN I DO IT. AND WILL IT DAMAGE THE ENGINE IF DONE.
AK
antonio
Postby bluemaumau » Mon Jan 29, 2007 11:09 pm
nominated for post of the year.
you need the afm, unless you have a aftermarket ecu
Postby Dell'Orto » Mon Jan 29, 2007 11:12 pm
Computer says noooooooooooooo
Postby antonio » Mon Jan 29, 2007 11:18 pm
i have a 20v silvertop, isnt that afm
AK
antonio
Postby big_boy » Mon Jan 29, 2007 11:20 pm
im not gona say any thing :lol: :lol: :lol: :lol: :lol:
NO
how alse are you gona mount it if it cant bolt up to the AFM
& NO an AFM is not like a apendix they are accually put there for a reason
for sale EE90
big_boy
Postby big_boy » Mon Jan 29, 2007 11:22 pm
antonio wrote:i have a 20v silvertop, isnt that afm
i wouldent have thort so i thort they were MAP
what douse your AFM apair to look like
for sale EE90
big_boy
Postby antonio » Mon Jan 29, 2007 11:26 pm
Im not sure but the afm looks like small box just after the intake throttle body chamber, then after the small afm box is the filter box
AK
antonio
Postby big_boy » Mon Jan 29, 2007 11:28 pm
if its AFM it will go filter-pipe-AFM-pipe-TPS-manfold is it like that
for sale EE90
big_boy
Postby Lloyd » Mon Jan 29, 2007 11:30 pm
No you can not do that. The airflow meter is in there to meter how much air goes into the engine. Its the primary signal to tell the ECU how much fuel is needed for the engine to run.
If you get rid of it your car will not go
Dont do it
Postby antonio » Mon Jan 29, 2007 11:30 pm
sorry bro whats tps manifold
AK
antonio
Postby AceSniper » Mon Jan 29, 2007 11:30 pm
:roll:
AceSniper
Postby AceSniper » Mon Jan 29, 2007 11:31 pm
AFM also has the fuel pump relay switch init
AceSniper
Postby big_boy » Mon Jan 29, 2007 11:33 pm
i think its best you get some one alse to look at you car & conform what set up your ruuning first or can you take a pic so we can conform what your talking about
TPS= throtle pission sensour
manfold = the bit that bolts to the head & the TPS
for sale EE90
big_boy
AceSniper wrote:AFM also has the fuel pump relay switch init
only on the early ones
for sale EE90
big_boy
Postby AceSniper » Mon Jan 29, 2007 11:34 pm
It will be filter box, afm, pipe, plenum, quads
you can't remove the AFM
AceSniper
Postby antonio » Mon Jan 29, 2007 11:35 pm
cant you replce it with someting else. because ive got a scoop on my hood and i wanna ram air down straight into the modified throttle body box ramming the cold air straight in.
AK
antonio
Postby AceSniper » Mon Jan 29, 2007 11:36 pm
he stated it was silvertop
AceSniper
you cant remove the afm unless you do sumthen long the lines of a aftermarket ecu, or run a blacktop map loom and ecu
AceSniper
Postby Lloyd » Mon Jan 29, 2007 11:37 pm
Your options are keep the AFM, or buy an aftermarket computer and run a MAP sensor. Those are your choices.
Postby antonio » Mon Jan 29, 2007 11:37 pm
I guess its a no go, sweet az cheers for the info quys
AK
antonio
