Trying to take airflow meter of and run straight k&N FIL
Postby big_boy » Mon Jan 29, 2007 11:38 pm
AceSniper wrote:It will be filter box, afm, pipe, plenum, quads
you can't remove the AFM
antonio wrote:Im not sure but the afm looks like small box just after the intake throttle body chamber, then after the small afm box is the filter box
thats a good point there is it a MAP version with a plenum (this is not a AFM if thats what your looking at)
take a picture
for sale EE90
big_boy
Postby AceSniper » Mon Jan 29, 2007 11:41 pm
the map version is blacktop.......
he could plug a blacktop loom into his engine with blacktop ecu then wire the car side into it.
AceSniper
Postby big_boy » Tue Jan 30, 2007 8:27 am
oh ok i thort you could get MAP silver tops theres 2 in dunedin that i know of but there probley black harness then
for sale EE90
big_boy
Postby sergei » Tue Jan 30, 2007 9:27 am
He does not have to get MAP sensor loom just to fit poddie ;).
What he needs is $20 adapter.
There is no real gain running blacktop loom on silvertop engine.
The AFM is not as restrictive as people think. 0.3% of $&#$% all.
Postby HELBND » Tue Jan 30, 2007 9:39 am
big_boy wrote:
antonio wrote:i have a 20v silvertop, isnt that afm
i wouldent have thort so i thort they were MAP
what douse your AFM apair to look like
stop talking out your ass - all the silvertops are AFM :roll:
HELBND
Postby AceSniper » Tue Jan 30, 2007 10:58 am
he was saying he didnt want the afm... so he could ram air from a bonet scoop...
AceSniper
Postby sergei » Tue Jan 30, 2007 11:06 am
Oh BTW "ram air" does not work from bonnet scoop (you get low pressure there), it is wrong shape, and to get ram air effect you need something in this shape doing similar speeds of that car:
Or look at the jet engine shapes...
To get high pressure in intake the inlet hole should be smaller than the actual throttle body...
After googling for about 10sec I found these articles:
http://forums.corvetteforum.com/showthread.php?t=1129295&highlight=ram+air&forum_id=1
http://www.bmwe30.net/cgi-bin/datacgi/database.cgi?file=articles&report=view&ID=00004&Section=03
http://www.allfordmustangs.com/forums/4-6l-tech/18409-the-ram-air-myth-9.html
Postby larryex » Tue Jan 30, 2007 7:14 pm
[quote
TPS= throtle pission sensour
[/quote]
Is that like a throttle position sensor?
or is it different?
larryex
Postby Lloyd » Tue Jan 30, 2007 7:20 pm
I think this thread has served its purpose
