mixing red with blue
Postby potz » Wed Jan 31, 2007 10:02 pm
hi can anyone tell me if i can use red top engine [ae92] with blue top computer and loom [ae82]
potz
potz
Postby Brick » Thu Feb 01, 2007 11:20 am
i run bluetop loom on my smallport, there was one sensor plug i had to change but besides that there were a few plugs i didnt need.
unsure aboout ecu as i run an aftermarket one so may not work
Brick
I know Kung Fu
Postby Zak » Thu Feb 01, 2007 11:37 am
what kind of red top are you trying to run? Big or small port?
Either way, both will work, just use the blue top dizzy and ignitor + coil.
Zak
Postby crispy'86 » Thu Feb 01, 2007 7:13 pm
in my experience the plugs are different for the injectors between the bluetop and redtop, bluetop has those nice wire clips round the plug whereas the redtop has the plug-in type. Use the bluetop coil igniter too as redtop have totally different setup on them
crispy'86
Postby potz » Thu Feb 01, 2007 9:50 pm
cheers guys engine is a day away from firing up.
fingers crossed
potz
potz
Postby l1ttle_d3vil » Thu Feb 01, 2007 10:01 pm
you'll need bluetop injectors too won't you? because the plugs are different from the redtops...basically any of the redtop sensors which don't plug in to the bluetop loom, you'll need to swap for bluetop sensors...you could get away with just swapping loom plugs for some sensors though.
hope that makes sense. :lol:
Postby potz » Thu Feb 01, 2007 10:42 pm
yes have used blue top everything apart from block, head and inlet manifold
potz
potz
Postby potz » Sun Feb 04, 2007 8:12 pm
yahoo all go. running sweet
potz
potz
