l1ttle_d3vil wrote:is it possible to use the standard outlet by the oil pump on 4agzes as a feed? or is that too small? and does the same apply to the return line thats already fitted to 4agze sumps? I think the lines were for p/s originally, are they too small for turbo lines?
slighty_sykotic wrote::roll:
What the hell...
If that light EVER comes on when driving, you've got a pretty good chance for $&#$% something, so weather or not the light is there, things are going to be bad.
Answer = Don't run out of oil...
evil_si wrote:never had an issue.
fit a 't' piece into were the oil pressure sensor goes and run your turbo oil feed from here
Psycho_Dad wrote:evil_si wrote:never had an issue.
someone wanna show me a photo of one of these sensors on the block? they are just left of the oil filter with a single wire coming off them?
cheers in advance
PSycho_Dad
slighty_sykotic wrote:In that one yup,
But many of the early 4ages its round. like:....[/img]
