Dont rely on maths and drivetrain calculations, etc
tp got my rpm all fuked up, apparently I redline below 7000rpm (around 6800) with a 4age. big load of crap.
only true way to tell is to hook up the dyno and the -ign output.
Interesting... Surely the dyno's road speed can't be wrong since isn't it measured from the rollers... i didn't go from the TP RPM readout. I went off their road speed.Caveman wrote:Dont rely on maths and drivetrain calculations, etc
It's not too hard... I'm too lazyCaveman wrote:Yea sorry I didnt intend to put down your maths
the problem is you dont know for certain the accuracy of the dyno speed, tyre size, gear ratios, etc
eg a tyre diameter will change as speed increases. not by much but still introduces error
im just saying for a difinitive result, your -ign will provide a descrete and accurate result.
then work from there.
I think a speed sensor going into the ecu would help, as some cars lower the rpm limit while at idle
or run a megasquirt, and dont give me its too hard excuse, mr electrical engineer
NZ_AE86 wrote:Tyre size varies from one brand to another so working speeds out from that is a waste of time!
dash wrote:On our nissan s13 forum, a 'crystal' was swapped in the ecu to raise the rev limit. Apparently they guy knew about ecus and how to calculate it. Experiment worked.
dunno if toyota ecu has one
