yea im a noob to toyspeed but not to toyotas...
Just wanting to know as i have just installed a BOV on a st185 GT4 and well, its not doing what it should.
I have run an extra pipe off the front elbow bend of the factory top mount IC, and thats all well and dandy. The vacuum i have run is off a blanked off one at the back (and sort of underside) of the intake plenum, this has quite a strong vacuum.
My problem tho is that the BOV opens when it should but takes abouut 2-3 seconds to close and makes a gay ass whistling noise when it does...
I suspect this is because of the rubber rings in the BOV (yes it is a cheap one)
Has anyone else had this problem or similar? is it possible that its caused by too much vacuum?
Can anyone help??!!
