asweetdude wrote:i can get hold of some 2.2l injectors if theyll be big enough. got an auction number?
asweetdude wrote:Hi all,
Has anyone done a turbo upgrade on a Gen2 3SGTE? (ST185 GT4)
reason i ask is im wanting to know what sort of boost i can run without blowing the engine to bits.
Was thinking of running the CT26 un gated but ive heard they like to spit their parts out your exhaust if you do this to them.
Can anyone confirm this?
Also, If anyone has done a turbo upgrade, what did you use and how much did it cost? i wanna stay away from using new headers etc. so one that bolts to the factory flange would be good. Am not too worried about gettin a custom down pipe as theyre not very expensive.
Phothog wrote:gets rid of the lack of power above 5,500rpm
and bolts back on in place... no mods need to fit...
Mmm, Boost wrote:Phothog wrote:gets rid of the lack of power above 5,500rpm
Got dyno plots of cars fitted with these? I'd be quite keen to see.
asweetdude wrote:Hmm, if your price isnt too bad, i think it could be a good option, as my engine has done high kms.. and is due for a cambelt in the next 10 thou.
Then again, gettin my engine to auckland and then back might not be so easy.
pretty simple..
1 x 46trim T04E Compressor wheel (new of course)
1 x Steel turbine wheel & shaft assembly (new of course)
machine Compressor wheel, bearing housing & Compressor cover to suit.
rebuild (Bearings, Piston rings, Orings, etc...)
all up including labour & machining and GST $1,480..
MR2SIK wrote:definatly ct20b for ease of installation and cost.
they pop up on here or trademe every now and then for between $500-700.
Mr Revhead does them new for about $2000.
depending on how much you love your car it will get you a low 13 or a high 12 down the 1/4 mile.
asweetdude wrote:Sounds very tempting, but still, dont know if the engine will handle the extra boost. what does a CT20B run anyway? Keeping in mind that my car has done 194000kms. Although it doesnt smoke or show any signs of having mechanical issues.
