Just a small idea.. throttle bodies...
Postby bbq1988 » Fri Feb 16, 2007 1:28 pm
Hey guys, ive got a set of SR20DET ITB's sitting at home, has anyone heard of them being mated to a 3s-ge?
Baked, Not Fried.
bbq1988
not me
Postby TOYROTA » Fri Feb 16, 2007 1:33 pm
i havent heard of them bein used however i reckon it could be a good idea how are they in comparison to 20v ones?
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby bbq1988 » Fri Feb 16, 2007 2:26 pm
not 100% sure, i think ill measure them this weekend, might be interesting to find out, does anyone have any measurements of the 20v ones? also whos fitted the 20v ITB to a 3s?
Baked, Not Fried.
bbq1988
Postby atmosports » Fri Feb 16, 2007 9:36 pm
I've fitted 20V throttle bodies to a 3S before, both gen1 & 2 engines, but then for me it's basically a bolt on as I've got all the manifold etc at my disposal unless space is an issue like on an mr2(or so I'm led to believe that my manifolds are too long). Do a search for the 20V TB sizes as they have been mentionsed before 42mm sounds familar, can't remember what the sr20 ones are but I've fitted them to a SR16 before.
atmosports
Postby strx7 » Sat Feb 17, 2007 8:00 am
i think from memory GTiR quads are 45mm each
Postby Crampy » Sat Feb 17, 2007 11:10 pm
strx7 wrote:i think from memory GTiR quads are 45mm each
That'd make them the same size as the Blacktop 20 Valve ones.
Crampy
Postby AE25 » Sat Feb 17, 2007 11:27 pm
net sources say 20v silvertop are 43mm, blacktop 45mm and GTiR 45mm
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby Crampy » Sun Feb 18, 2007 9:26 am
You'll have to see how easy it'll be to make up a manifold to suit and then see if you can get the Toyota TPS on the GTiR quads too.
Crampy
Postby atmosports » Sun Feb 18, 2007 2:51 pm
Manifold shouldn't be too difficult, but then I say that as I'm forever playing with manifolds to put this onto that & it's quite amazing how many other engines a st205 side draught manifold will actually fit ith a bit of cutting & filling.
You wo't necessarily need to fit the toyota tps, you'll just need a TPS that's the same style(either switch or variable resistor scaling type) & then you'll need to pick one which bolts onto your throttlebodies & rotates the right direction. The only last thing to worry about is output voltage & the plug/wirinbg it up, you'll more than likely find the nissan one would work with just a plug change especially if your running an aftermarket ecu of some kind.
atmosports
Postby Crampy » Sun Feb 18, 2007 4:40 pm
atmosports wrote:Manifold shouldn't be too difficult, but then I say that as I'm forever playing with manifolds to put this onto that & it's quite amazing how many other engines a st205 side draught manifold will actually fit ith a bit of cutting & filling.
Also, if you're car is MAP sensored, you might need a vacuum accumulator or chamber of sorts. Like the guys using silvertop 4AGEs with aftermarket MAP ecus, that vacuum is too erratic at idle when using the vacuum off a single runner.
Crampy
Users browsing this forum: Bing [Bot] and 4 guests
