BOV Issues St185 GT4 Celica
Postby slighty_sykotic » Fri Feb 16, 2007 12:02 pm
UTERUS wrote:
And compressor surge isn't?
Not as far as anyone can prove to me.
Prove to me compressor surge is bad.
slighty_sykotic
Postby slighty_sykotic » Mon Feb 19, 2007 2:48 pm
slighty_sykotic
Postby fivebob » Mon Feb 19, 2007 3:55 pm
slighty_sykotic wrote:Prove to me compressor surge is bad.
What standard of proof do you require?
Anyone with a modicum of intelligence can see that reversing flow though a compressor spinning at 100,000+rpm isn't going to be good for it. At the very least it heats the air up dramatically, at the worst it will break the shaft (ask Akane about that one), or damage the bearings or compressor vanes.
In short, compressor surge should be avoided, it's bad for the turbo, enough said.
Postby Prymal » Mon Feb 19, 2007 5:00 pm
As promised - juts a quick overview of my piping setup
There is NO AFM - as i used an aftermarket ECU on this machine
FMIC cooling was well capable of 170 + KW at the wheels on a standard ( steel shaft ) turbo - All pipes were HPC coated Stainless steel
Prymal
Postby Norty » Mon Feb 19, 2007 5:15 pm
I notice that nobody seems to run extractors any reasons why?
Norty
Postby Prymal » Mon Feb 19, 2007 5:20 pm
because you dont need to
the stock 3sgte manifold is perfectly good for flow , just doesnt look all bling
if your going for mega Horsepower , a tubular manifold is a good thing to adapt up to say, a garret to position it better , but yeah - i know at least 5 examples personally running over 220 KW at the wheels with just the stock unit
Prymal
Postby Norty » Mon Feb 19, 2007 5:26 pm
So what your saying is i will gain nothing other than wank factor from the extractors? no power gain no back pressure gain, no 35% increase in power no nothing unless i run like mad insane power?
i come from a N/A world where extractors did something to your car, so the factory manifold is sweet
Thanks for the info you may of saved me some dollars
Norty
Postby Prymal » Mon Feb 19, 2007 5:49 pm
Oh youll get the very noticable benifits - about 20 or so extra HP at least but its really an unneccessary expense unless your chasing huge numbers.
For my group A - it will be a finishing touch - for the look , and for the final gain of HP , before that - you can get much better results simply by a decent exhaust off the turbo back , and a decent intercooler ( ie frontmount on a St185 )
Prymal
Postby Adydas » Mon Feb 19, 2007 6:27 pm
My turbos fitted via factory manifold, using a Blitz Turbo kit.
I spent money on, allmost everything for my build and at no stage was it highlighted or an issue to replace it.
Adydas
Postby Boosted_162 » Tue Feb 20, 2007 12:37 am
Im only using a new manifold cos ill be running a completely different turbo, and i didnt want to go to the haslse of getting different flanges welded on etc. Plus a little bling never hurt anyone :lol: :lol: (no shiny bits tho :P)
Postby Malcolm » Tue Feb 20, 2007 8:48 am
classique71 wrote:Oh youll get the very noticable benifits - about 20 or so extra HP at least but its really an unneccessary expense unless your chasing huge numbers.
that's pretty damn ambitious, are we on a Tui billboard or something?
Postby Prymal » Tue Feb 20, 2007 1:19 pm
thats what the guys at aussie exhausts say they found from their upgrade manifold if i recall , I may be wrong .. if anyone wants to buy me one - so i can back to back test - your welcome to do so!
Prymal
