HID lights
Postby UTERUS » Tue Feb 27, 2007 9:59 pm
Mr.Phreak wrote:Although they're only useful if you pick temps that have decent visibility.....otherwise you're just posing
Correct, any temp lower than 6000k is best. Higher colour temp you go the bluer it becomes and the light output is less.
UTERUS
Postby vvega » Tue Feb 27, 2007 11:05 pm
Correct, any temp lower than 6000k is best. Higher colour temp you go the bluer it becomes and the light output in the spectrum you can see is less.
just had to fix that up
vvega
Postby BlakJak » Tue Feb 27, 2007 11:18 pm
Lighting rule info is in the FAQ section.
viewtopic.php?t=45506
Note:
3.2(4) The horizontal orientation of a headlamp on a vehicle must, when the vehicle’s front wheels are pointing in the straight-ahead position, ensure that the centre-line of the beam of light emitted from the lamp is projected either parallel to, or to the left of, the longitudinal centre-line of the vehicle.
3.2(6) A dipped-beam headlamp designed solely for a left-hand-drive motor vehicle, where the maximum intensity of the beam is dispersed to the right, must not be fitted to a vehicle.
12.1(1) A modification to a motor vehicle that affects the performance of its lighting equipment:
* (a) must not prevent the vehicle from complying with the applicable requirements of this rule; and
* (b) must be certified in accordance with Land Transport Rule: Vehicle Standards Compliance 2002.
The Vehicle Standards Compliance Rule 2002 goes on to state in some detail what requires certification...
If people have an opinion as to whether HIDs construe a 'modification' per the above, am interested...
BlakJak
Postby 2jayzgte » Wed Feb 28, 2007 7:11 am
I thought HID kits were illegal I to have looked at getting a set for my car please can someone set me straight on this...
2jayzgte
Postby Mr.Phreak » Wed Feb 28, 2007 8:49 am
Bulb kits are.....Complete housing conversions aren't (as long as they comply with standards)
As per http://www.ltsa.govt.nz/vehicles/get-yo ... right.html
"High intensity discharge (HID) conversion kits
HID conversion kits (an HID bulb with a high voltage power unit or ‘ballast’ which fits into the original headlamp unit in place of the original bulb with no change to the headlamp lens, reflector or housing) are illegal on any vehicle being used on New Zealand roads.
However, a complete halogen headlamp unit can be replaced with a complete HID headlamp unit provided that the replacement headlamp unit complies with approved standards. If in doubt, get advice from a vehicle lighting retailer you trust."
Mr.Phreak
Postby barryogen » Wed Feb 28, 2007 12:21 pm
when pricing up a full kit from Toyota for my corolla, it was ~$3k for the two front lights... approx $2k through revhead from memory... I still have "normal" lights.
barryogen
2ZZ Guru in training
Postby B ROWDY » Wed Feb 28, 2007 12:52 pm
Mr.Phreak wrote:Bulb kits are.....Complete housing conversions aren't (as long as they comply with standards)
Mr Phreak has it in a nutshell sunshine, if you know the brand then post it here and I can tell you if they comply or not, or if you want a list I can make one for you if thats easier??
Chur chur B~ROWDY
B~ROWDY The Thread Whore Formerly Known As SERABABY
B ROWDY
Postby 2LTR Rona » Wed Feb 28, 2007 1:07 pm
B ROWDY - if you have a list of known compliant kits at the moment then by all means post that up, it could then be placed in somewhere like FAQ's etc for reference & added to or modified as needed.
2002 Altezza, 1974 KE25
2LTR Rona
Postby Mr.Phreak » Wed Feb 28, 2007 3:40 pm
B ROWDY wrote:or if you want a list I can make one for you if thats easier??
Chur chur B~ROWDY
Yes Please :D
Mr.Phreak
Postby B ROWDY » Wed Feb 28, 2007 3:43 pm
Not of specific compliant kits, but of the company names & standards etc
B ROWDY
Postby GTCRSHR » Wed Feb 28, 2007 4:07 pm
barryogen wrote:when pricing up a full kit from Toyota for my corolla, it was ~$3k for the two front lights... approx $2k through revhead from memory... I still have "normal" lights.
they look dam good tho, i saw one the other night with a set, looks fantastic
Nothing to see here ...
GTCRSHR
Postby Mr Revhead » Wed Feb 28, 2007 5:24 pm
LHD drive head lamps = not legal
and just coz one wof guy says "i dont care" means nothing
cops can still ping you.
and if another wof guy see its and enters it in the wof syste, your screwed
we had an issue with a tundra that had wofs at a "local" garage for 5 years.
then came here and got failed on the lamps..... man that caused a headache! :lol:
and re the WRC cars, theres provsions for cars like that to get exemptions, which is why they are allowed mirror tints etc.
Postby 2jayzgte » Wed Feb 28, 2007 5:36 pm
Chur chur B~ROWDY
TRD HID kit for the Jza 80 Supra legal or illegal???????
2jayzgte
Postby vvega » Wed Feb 28, 2007 5:38 pm
BlakJak wrote:Lighting rule info is in the FAQ section.
Note:
as far as modiforcation goes
anything that is not supplied OEM is and can be considered a modiforcation
OEM = what that specific car left the factory with
vvega
Postby deaf_rattle » Wed Feb 28, 2007 5:41 pm
Mr Revhead wrote:and if another wof guy see its and enters it in the wof syste, your screwed
i dont understand. i have never once seen the warrant people look up the car details before the warrant check has been done.
so what difference does it make if they enter it into the system?
Postby beeker » Wed Feb 28, 2007 6:55 pm
From memory my Audi has a flip on the back of the lamp housing to move it from Left lane drivng to Right lane driving. As you can imagine in Europe/England, this would be important.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Mr.Phreak » Wed Feb 28, 2007 7:56 pm
2jayzgte wrote:TRD HID kit for the Jza 80 Supra legal or illegal???????
I would assume they meet the required standards, although I'd be waiting for to confirm. I think it'd probably be a grey area though, and I'm pretty sure they don't make em anymore
Mr.Phreak
Postby Mr Revhead » Wed Feb 28, 2007 8:17 pm
if your car fails, they enter the reason why into the database.
so if you go elsewhere, it shows up when they enter the details
Postby deaf_rattle » Wed Feb 28, 2007 8:46 pm
yeah, i understand that part. But you could just go to a completely different place and they would give you an inspection and wouldnt see the note untill after they had done the check.
unless there is something i am missing?
They dont view the details until entering the results of the inspection in.
Postby 2jayzgte » Wed Feb 28, 2007 9:28 pm
Thats what I would suspect that they would be legal now Mr.Revhead all we need is that e-mail from Japan and I'm set..... :wink:
2jayzgte
