strx7 wrote:std boost and not more than a fraction higher
14-15psi is std from memory, and 17-18psi on run of the mill 96 = 3 pistons left.
you could up it to 17psi but MAKE SURE it gets 98 octane and nothing less.
barryogen wrote:figured... is it a limit of the fueling or something else?
fivebob wrote:There's plenty of fuel. The limit is 9:1 compression, stock ignition curve which is tuned for 100 octane, and the stock interwarmer (+ hot weather)
JIZRAG wrote:Id say leave it stock boost, 3sgte's are very strong motors in stock form. if you approach modifying them in a sensible manner
JIZRAG wrote:Id say leave it stock boost, 3sgte's arent very strong motors in stock form. Ask PRYMAL about his experience with them. he smashed a piston to shreds running 17psi and running higher fuel pressure than stock.
fivebob wrote:JIZRAG wrote:Id say leave it stock boost, 3sgte's are very strong motors in stock form. if you approach modifying them in a sensible manner
Corrected for truth![]()
BTW you can extract 500HP from the stock internals if you do it properly, and it's as reliable as any other 500HP 2 litre engine that is built on a budget
JIZRAG wrote: Ask PRYMAL about his experience with them.
