more problems/ clutch
Postby bluemaumau » Thu Mar 08, 2007 11:14 am
well as soon as i get my idle fixed i get struck down with another problem
:roll: :cry:
i satrted the car. clutch in. reverse selected. realesed clutch. with no throttle it starts picking up revs. clutch in. neutral selcted. goes to 3000rpm. turn car off.
wtf
the clutch is 350kms old, as is the pressure plate. the flywheel is machined. torqued together at app torque. bleed clutch system
so can anybody diagnose the problem, cause i sure as hell dont want to remove my gearbox again.
can a bung master/slave cyclinder be the culprit?
thanks in advance
Postby sergei » Thu Mar 08, 2007 11:16 am
Check for free play in clutch pedal. Also check if you can push in the clutch slave cylinder with fingers (by pushin cylinder end of the fork).
Postby bluemaumau » Thu Mar 08, 2007 11:19 am
i can push the nipple on the slave back into itself if thats what you mean?
Re: more problems/ clutch
Postby solberg Fan » Thu Mar 08, 2007 11:03 pm
bluemaumau wrote:well as soon as i get my idle fixed i get struck down with another problem
:roll: :cry:
wtf
Let me get this right. The idle picked up when you let the clutch out in reverse? With out touching the throtle at all? Did the car move at all with the clutch out while in gear? Also were you playing with the brake pedal at all?
The brake pedal could effect you idle but not the clutch peddal. (unless toyota has developed some kind of vacume assisted clutch that I highly dout.)
Im just trying to get a full picture. At this point im thinking you havnt solved you Idle problem.....
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
solberg Fan
Postby bluemaumau » Thu Mar 08, 2007 11:05 pm
yup your right. it seems as soon as it moved its gone back to the idle problems
before i moved car:
no error codes
warmish steady idle @950/1000rpm
after
error code 51
steady idle @ 2500rpm
random huh
Postby matt dunn » Thu Mar 08, 2007 11:10 pm
re set your TPS
Postby bluemaumau » Thu Mar 08, 2007 11:26 pm
ok matt,
can you tell me why you think this just occured as i drove it?
Users browsing this forum: Bing [Bot] and 17 guests
