ISC/rotary soleniod
ISC/rotary soleniod
Postby bluemaumau » Mon Mar 26, 2007 10:29 pm
hey all
ive taken my whole inlet off in order to try and stop the high idle issue.
i also want to check the wiring associated to the ISC/Rotary soleniod.
there are three wires
red
black
green.
i have some ideas where they go but would like confirmation.
just to save me ripping the 1cm thick skin of loom tape that has engulfed my loom :lol:
ae92 afm 4agze btw
Postby matt dunn » Mon Mar 26, 2007 11:26 pm
the centre one is the red??
Red is Ign power /12V feed
the other two are ISC and ISO which both go to the ECU.
Postby bluemaumau » Tue Mar 27, 2007 12:16 am
cheers matt
Postby bluemaumau » Tue Mar 27, 2007 12:24 am
http://home.clear.net.nz/pages/phil.bra ... 20Pins.htm
according to this pins 2 and 7 on the 10 pin plug are ISC related.
but it says the red and green wires.
Postby matt dunn » Tue Mar 27, 2007 12:27 am
Ah yes
red and Green are ISC and ISO,
and the Black wire will have a tracer colour, probably red trace signaling ign switched power.
The trace colours in wires are just as important as the main colour in working out what they do)
(I can only remember so many colour codes from memory.)
Postby bluemaumau » Tue Mar 27, 2007 12:30 am
sweet as cheers matt,
ill check the continuity of those tomorrow, and hopefully eliminate that possibility
