Hey guys,
My windscreen wipers have been playing up recently and when I use them they sometimes get a mind of their own and start wiping on the normal speed (the one directly after intermittent) regardless of the position the switch is in (unless its on the fastest speed in which case i dont notice until i slow them down or turn them off, and they keep going)
As you can imagine this can get pretty annoying, because if the rain stops and the wipers keep going they get noisy (obviously because the windscreen is dry) and the only way to stop it is to pull over and unplug the wiper motor, because even turning the car off and on again doesn't always work.
Any ideas?
