replacing rear drum breaks on ae92 wagon
Postby SkunkWeRX » Fri Mar 30, 2007 8:43 pm
hey guys how the hell do i get the drums off on my wagon??? the shoes need replacing hard out
any help would be sweet
thanks
SkunkWeRX
Postby big_boy » Fri Mar 30, 2007 10:41 pm
iff there the same as EE90 should be the came off with a little tap from mister convinceing stick :twisted:
also rembour you need to let you hand break off 1st
for sale EE90
big_boy
Postby sergei » Fri Mar 30, 2007 11:18 pm
there is a 6 or 8mm threads on the drum in same area as studs, just screw couple of bolts in (after you let the handbrake off).
There is sometimes problem with removing the drum because there is too much wear and it pads are dugg in the drum. To fix that you have to screw in the handbrake adjuster ratchet with screw driver (accessible through hole in the drum again next to studs)
Postby SkunkWeRX » Sat Mar 31, 2007 10:22 pm
ok i was doing it with the hand break on hahahaha doh!!!
dam fool!.;0
SkunkWeRX
Postby SkunkWeRX » Sun Apr 01, 2007 9:14 pm
managed to do one of em the other is fully stuck on!
ya rekon i could put those bolts u mentioned in those holes an use them lit a panell puller kind stlye or would it warp the drum ???
SkunkWeRX
Postby sergei » Sun Apr 01, 2007 11:54 pm
have you tried some hammer/CRC persuasion?
I doubt it will warp drum if you use some sort of puller using those holes.
Postby SkunkWeRX » Mon Apr 02, 2007 10:37 pm
could i just keep doing the bolts up untill it forces the drum outwards??
SkunkWeRX
Postby XSVWGN » Thu Apr 05, 2007 8:01 pm
just remove the drums with a massive hammer and get some disc breaks :twisted:
2008 Kia rio - work car
XSVWGN
