What turbo does a 98 Caldina GT-T run standard on a 3SGTE
Postby Heapho » Sat Mar 31, 2007 2:06 pm
Any help would be appreciated thanks ! I own a Caldina GT-T but haven't got It yet its in Auckland on th port I get it on Monday ! But I just want to know what turbo they run
Tom
Heapho
Postby groupagt4 » Sat Mar 31, 2007 2:26 pm
ct20b
groupagt4
Postby Mr Revhead » Sat Mar 31, 2007 2:39 pm
im pretty sure thats not correct.
iirc they are a different unit again from the ct20b/ct26
why do you want to know?
Postby fivebob » Sat Mar 31, 2007 2:59 pm
groupagt4 wrote:ct20b
Nope, they have the same compressor, but a different exhaust turbine. It's a single entry steel turbine. Not sure what it's called in the real world, but I've seen a few references to it's internet persona being know as a CT15B :twisted:
Postby sergei » Sat Mar 31, 2007 3:37 pm
Slightly off topic but the exhaust wheel looks smaller then on CT20b..
also they have poorly designed one piece exhaust manifold/exhaust turbine housing.
I think Toyota decided to save some money and ditch twin entry same time...
Postby groupagt4 » Sat Mar 31, 2007 6:59 pm
ops my bad :oops:
groupagt4
Postby Heapho » Sat Mar 31, 2007 7:08 pm
I'm just wanting to find out what the turbo is because I'm trying to find a stainless manifold for it
Heapho
Postby fivebob » Sat Mar 31, 2007 9:07 pm
Heapho wrote:I'm just wanting to find out what the turbo is because I'm trying to find a stainless manifold for it
Can't be done, the manifold and the turbo are one piece. If you are going to replace the turbo as well then any manifold for a Gen III 3S-GTE will fit.
Postby the fallen303 » Sat Mar 31, 2007 9:07 pm
isn't the ct15b also what came on the 1jz-gte single turbo in the chasers, etc?
true house of JZ
Stay true to the origin
the fallen303
Postby gleem » Sun Apr 01, 2007 1:17 pm
also i am pretty sure driven performance will be selling off the shelf manifolds to go with a t3/t4 for a gt-t
gleem
Postby Steve123 » Fri Apr 06, 2007 2:02 am
They have CT20 stamped on them dont they?
Steve123
Postby fivebob » Fri Apr 06, 2007 2:07 am
Steve123 wrote:They have CT20 stamped on them dont they?
Where? Not that I've ever seen, nor for that matter do GenIII CT20B's
Postby vvega » Fri Apr 06, 2007 9:18 am
not even close
the only marking they have is toyota
unless your getting comfused with a shitty old ct20 off a 3t
they have ct20 stamped on them
vvega
Postby gleem » Fri Apr 06, 2007 12:44 pm
if your only reason for this is to wastegate it you can get a port welded on to the stock one
gleem
Postby fivebob » Fri Apr 06, 2007 3:19 pm
gleem wrote:if your only reason for this is to wastegate it you can get a port welded on to the stock one
Why would you bother doing such a stupid modification?
Postby flygt4 » Fri Apr 06, 2007 9:57 pm
because it sounds cool, and you can " 'gate it" past the 5-0 and get yo car impounded au :wink:
believe it or not, i have actually heard the word gate used as a verb in that context :roll:
flygt4
Postby Steve123 » Fri Apr 06, 2007 11:49 pm
I must be mistaken
Steve123
Postby gleem » Sat Apr 07, 2007 12:01 am
i wouldn't bother but yea there is no point other than the sound, a person on trademe who has just done that for the sound buy the looks but yeh big waste off $500 on a stock turbo
gleem
Postby solitaire » Sat Apr 07, 2007 12:11 am
flygt4 wrote:because it sounds cool, and you can " 'gate it" past the 5-0 and get yo car impounded au
Actual lol followed by 5 minutes of explaining to the wife what i was laughing at and why it was funny :evil:
AE92, KZJ120, KDJ120
solitaire
Postby kim0663 » Wed Oct 07, 2009 3:29 pm
venting wastegates get the car impounded by the cops these days?
Mr2 GT-S
330ci M
kim0663
