SR20det into which shell, kp60 or ae85?
SR20DET into KP or AE85?
KP60
16
41%
AE85
23
59%
Total votes : 39
Postby Burning Angel » Fri Mar 23, 2007 8:17 pm
well im putting an sr20de in my starlet and i would have to say its not hard.. just time consuming and requires alot of thinking.
the way mines set up the enigine come past the firewall for better wieght dist, even then theres no room really for a radiator behind the bonnet crossmemba. im tossing up between a twincore ek civic radiator or a cutom made 3core.
engine mounts are easy
gearbox is a bit of a pain as its soo long. you do have to cut the tunnel as the gearbox has sticking out bits and the starter hump. not sure about the dets but the de headers poke into the cockpit.
steering is fine but you will need bigger front brakes at the least.
im doing al the work myself or getting help from my brother and cousin so its not costing much.
in short do it to the 85 much easier.
Burning Angel
Postby mjrstar » Thu Apr 05, 2007 11:18 am
I have a 200+rw kw kp 60 bugeye, and it's really nice to drive the torque is awesome. it can get a little taily on the high boost setting.....
If you go for the square headlight starlet you'll gain about 50mm length under the bonnet. This might make things a little easier.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Return to Polls
