3T twin cam?
3T twin cam?
Postby TOYROTA » Wed Apr 11, 2007 1:12 pm
ok i just brought a 1980 corona wagon (tt134) or somethin along those lines it has a 3t engine and a t40 box.
i didnt think 3t engines came in single cam variety.
anyway its got some sort of electrical problem and wont start, the guy i got it from seems to think its got a problem with the dizzy so he supplied a spare dizzy and spare alternator.
does anyone have any comment on what problems the 3t motor commonly suffer from.
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby slonlo » Wed Apr 11, 2007 2:41 pm
2t and 3t were single cam push rod
2tg was dohc
3tgt dohc turbo - twin spark- monster
'89 LiteACE van
slonlo
Re: 3T twin cam?
Postby fangsport » Wed Apr 11, 2007 5:10 pm
TOYROTA wrote:does anyone have any comment on what problems the 3t motor commonly suffer from.
lack of respect!!
the motor is so basic, that there can only be a few things that stop it from running.
do you have fuel squirting down the carb throat? if not check fuel cut solenoid, then follow your way back toward tank for delivery issues
no spark? check dizzy timing and points gap, ballast resistor (if fitted), earth (one on head, another on block) leads etc.
still no go, then check fuses and relays.
fangsport
Postby AE25 » Sun Apr 22, 2007 6:41 pm
tt136 have a pushrod OHV 3t
sturdy basic engine as fangsport says
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Users browsing this forum: Google [Bot] and 1 guest
