CM Engineering Ashburton Street Sprints
Postby chch34 » Fri Apr 06, 2007 10:09 am
Yip got mine 8)
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Postby Blown5k » Fri Apr 06, 2007 9:16 pm
Well lets hope its not rained out this year.
Why dont they put it in the supplementary regulations that the results of the times of saturday will stand as a result for the event if rained out on the sunday?,at least you`d get a result for what is obviously an expensive event to run and will get everybody going for it and not sandbagging/foxing for sundays event.
Supercharged 5k kp60
2005-2006 1301-1600cc Canterbury Car Club race series champion.3rd 0-2500cc.
Blown5k
Postby Kahlua » Fri Apr 06, 2007 10:38 pm
Blown5k wrote:Well lets hope its not rained out this year.
Because of fairness - even though everyone finished their second run on the Saturday, this year could mean everyone could finish their second run and half could finish their third run.. or only 50% could finish their second run, however, at the end of the day a result can only be called if thats what the MSNZ approved Regulations state - and thats a full 2 days racing. And thats what I'm hoping for :)
If I say I don't need anyone
I can say these things to you
'Cause I can turn on any one
Just like I turned on you
I've got a tongue like a razor
A sweet switchblade knife
And I can do you favors
But then you'll do whatever I like
Kahlua
Postby fangsport » Sat Apr 07, 2007 12:00 am
write the regs so that in situation of force majure, results are calculated from the last completed run, piece of cake :wink:
fangsport
Postby matt dunn » Sun Apr 08, 2007 10:32 pm
fangsport wrote:write the regs so that in situation of force majure, results are calculated from the last completed run, piece of cake :wink:
Nah,
That will give you bogus results as you would have had someone like me who used the first run to learn where the track goes,
would get beaten by the guy who ran his mums corona at the event for the last 8 years.
Sure it may happen that way and you will be able to get a result,
but you might as well just post up the running order as the results list,
or draw the resluts from a hat as they will have nothing to do with who is the fastest..
Postby fangsport » Sun Apr 08, 2007 10:47 pm
double post
fangsport
Postby fangsport » Sun Apr 08, 2007 10:48 pm
Nah,
bollocks. it would be no different to any of those events that we run,
whereby at drivers breifing you state ' we are hoping to give you # runs each, but if delays occur, results will be calculated from the last completed run'
so you either risk relegation or go hard from the outset.
fangsport
Postby chch34 » Tue Apr 10, 2007 2:40 pm
would it be stupid of me to go out on a set of dunlop direzza's?
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Postby Kahlua » Tue Apr 10, 2007 8:27 pm
chch34 wrote:would it be stupid of me to go out on a set of dunlop direzza's?
I'll leave that for someone else.. (to be honest tyres are a f**king mystery to me)
Was speaking to Pat McMorran today (Chch Scrutineer for the Sprints) and he just said make sure your car turns up as its going to be raced on the day (as if you were heading for scrutineering 30 minutes before racing) - and remember to bring logbook, helmet and overalls. Mention if you are going to be taking passengers when you are there (if your car is up to the required spec) as they normally issue a second sticker then instead of the event.
I queried him about tyres, as I don't want to drive out there on the Dunlops, but he said as long as the tyres on it at the time could be scrutineered and passed its ok, (and as long as if you are using others on the day they would also have passed - keep in mind vehicles are audited randomly on the day, at the start and between runs, and you or your vehicle can't leave the event area without permission from the CoC or CRO). I guess the smart thing to do would be simply to throw the tyres you want to use (if you don't want to change them before scrutineering for some reason) in the back of the vehicle to be looked at then.
Unlike some other events I won't mention, your car will be jacked up so just make sure your car is sorted for the obvious things - your springs don't fall out once jacked up, your harness belts haven't expired, your steering system & throttle return are in good working order - you'll be fine.
From talking to quite a few different scrutineers in the past, its amazing how the majority of people fail on simple stuff like extinguisher not mounted correctly, expired belts, flammable overalls (yep) and expired helmets. :)
Kahlua
Postby Leon » Tue Apr 10, 2007 8:36 pm
My fave is the finger tight battery bolts, and self tapping screws holding extinguishers in, along with your list above 8)
Postby matt dunn » Tue Apr 10, 2007 8:48 pm
Um,
I think they are what Chris is going to run on the focus so I dont see why not??
Postby chch34 » Wed Apr 11, 2007 9:20 am
Um,
Wicked, cheers Matt!
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Postby DRFTIN » Fri Apr 13, 2007 8:33 pm
depends if you're as bad as me at braking, i screwed 3 V700's the 1st time i ran in the silvia
i want the starlet back it was way more fun
DRFTIN
Postby matt dunn » Fri Apr 13, 2007 9:52 pm
DRFTIN wrote:depends if you're as bad as me at braking, i screwed 3 V700's the 1st time i ran in the silvia
Basturd thing those tyres. great in all ways except there is no noise when they lock up.
Only way to tell you have locked a wheel is to see the smoke,
and by that time the tyre is stuffed.
Wrecked a real good tyre at Ruapuna like that when the brake bias was out of adjustment.
Postby chch34 » Sat Apr 14, 2007 12:03 am
yip last week i noticed my two front kumho v700 had nice bald spots.
Im out of street sprints until next year, my car wont be ready, again.
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Postby Kahlua » Sat Apr 14, 2007 12:21 am
chch34 wrote:yip last week i noticed my two front kumho v700 had nice bald spots.
Gutted mate. You still coming down to have a watch?
(I also guess you've let Shayne know you can't compete anymore so a reserve gets in / hence your money back?)
Hope to see you there anyway :) If you do, make sure you come over and say Hi.
Kahlua
Postby crispy'86 » Sat Apr 14, 2007 11:21 am
hey any way you could get someone else into that other place??
crispy'86
Postby chch34 » Sat Apr 14, 2007 12:38 pm
Yea ill let Shane know on monday. Might still go down for a look.
I think you'd have to be at the top of the reserves list to get in
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Postby Kahlua » Fri Apr 20, 2007 12:43 am
chch34 wrote:Yea ill let Shane know on monday. Might still go down for a look.
So you've let Shane know? Guess No.1 reserve will be happy.
Shame you couldn't make it dude.
Kahlua
Postby chch34 » Fri Apr 20, 2007 8:39 am
i have until may 10th to let him know. the guy thats bought my engine is paying today, so if my new engine shows up before next weekend, ill try get it in the hole and going be the 12th, just running on stock computer etc.
fingers crossed....
Dori Clothing Co.
www.teamSclub.co.nz
chch34
Return to Christchurch / Upper South Island Region
