V9 ECU?
V9 ECU?
Postby Levin » Sun Apr 15, 2007 9:54 pm
My friend just bought himself a 93 WRX, I've only seen it a few times, but from what I've seen it's had a fair few mods. I opened the glove box today to find a computer serial connection. So i traced the ribbon back to the ECU and found that it is a "V9" ECU. Anyone know anything about these or where I can get the software for it?
Tom
Levin
Postby Mr Revhead » Mon Apr 16, 2007 1:05 am
are u sure its not a stock ecu and you just found the plug in point for diagnostics?
Postby bluemaumau » Mon Apr 16, 2007 1:08 am
not a expert on subarus but its not a version 9 ecu? - do they even have V9s? :lol:
Postby atmosports » Mon Apr 16, 2007 11:27 am
What does the ribbon cable look like?? Look anything like the old Link hand controller ribbon cable???? If it's still in the standard case with a hole cut in the case & looks like an old link ribbon cable then it could be an early plug-in link. Though generally they'll have a sticker somewhere on the board stating what it is unless someone has removed it for some reason or another. Perhaps post up a pic of the cable/ecu if you can.
atmosports
Postby Levin » Mon Apr 16, 2007 7:38 pm
Thanks for the help. If you go to http://Tom-TB-.bebo.com and look under the photo's section, go to the album named random and you'll see a couple of pictures. I don't think its the factory ECU because the car is running 16psi, would the stock ECU have maps for boost that high?
Thanks, Tom
Levin
Postby matt dunn » Mon Apr 16, 2007 11:29 pm
yes later model Subaru turbo's are mapped and do run that higher boost as standard.
That is definatly a standard ECU case and numbers/sticker on it.
Post a picture of the non-ecu end of the ribbon cable for a better idea.
May have a link plugin in it as they just go inside the standard ECU box.
Postby mister2 » Tue Apr 17, 2007 10:09 am
Yep I'd say a PossumLink Plug-in, from the looks of that ribbon cable. They are a replacement board that fits inside the stock ECU case.
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby Levin » Tue Apr 17, 2007 7:02 pm
Thanks for the help. The other end of the ribbon looks just like a serial port on a computer. Anyone know what software I need to have a fiddle? Also what kind of things will this allow me to do?
Tom
Levin
Postby AceSniper » Tue Apr 17, 2007 8:22 pm
http://www.linkecu.com/support/dlandswu ... /Downloads
# PossumLink MY96 Manual
# PossumLink MY98 Manual
# PossumLink MY99 Manual
# PossumLink 44S Manual
AceSniper
Postby Levin » Tue Apr 17, 2007 10:55 pm
cheers AceSniper, i think I'm set now. I don't plan to do any tuning, just want to see sensor readings etc. Thanks for all the help.
Levin
