Are all SC12's created equal?
Postby DB4G63 » Tue Apr 17, 2007 5:30 pm
Random question I know....
is there any difference between earlier MR2 SC12's AE92 SC12's and AE101 SC12's?
Just wondering, I realized the earlier 4AGZE run lower compression...
just would help in my hunt for a new one...
thanks!
"If I'm a child that means you're a pedophile, and I'll be damned if i'm going stand here and take this from a pervert."
Wheels: AE101 1993 GTZ Trueno (S/C)
DB4G63
Postby Rick » Tue Apr 17, 2007 5:38 pm
The superchargers are the same however they did use different size pulleys on the superchargers which would make a small difference in power, the pulleys are interchangeable.
Postby Crucible » Tue Apr 17, 2007 6:46 pm
ae101 has the smaller s/c pulley
Crucible
Real Life Mechanic
Postby Pelo » Thu Apr 19, 2007 11:01 pm
The later type ones had SC12 stamped on the side, whereas the early large pulley types had no markings. Also some difference in the ribbing. And later ones had a cover on the front of the pulley, early just had the big cross piece.
Pelo
Postby bluemaumau » Fri Apr 20, 2007 1:47 am
mine has a cross on the pulley and sc12 stamped
(well actually it sticks out) on it also
