7AFE oversize piston
Postby normality78 » Thu Apr 19, 2007 1:33 am
does anyone out here know from which make model oversize car piston i can use for 7AFE? Be it low or high comp. "rumours" i heard 20V BT piston is 0.5mm bigger thn stock 7AFE piston. Anyone care to clarify?
normality78
Postby no_8wire » Thu Apr 19, 2007 8:39 am
4age piston=same bore as 7afe
no_8wire
Postby Mr Revhead » Thu Apr 19, 2007 9:51 am
yeah as above.
iirc you need to do some calcs on the compression ratio as 4age 10.4:1 pistons do not = 10.4:1 in 7afe
Postby normality78 » Fri Apr 20, 2007 5:11 am
ok. now its clear 4AGE piston same bore as 7AFE. So how about oversize piston? Any idea wat piston i can use?
normality78
Postby no_8wire » Fri Apr 20, 2007 8:32 am
How much oversize are you wanting to go?
Use a 0.5mm oversize 7afe piston from toyota?
no_8wire
Postby normality78 » Fri Apr 20, 2007 4:11 pm
no_8wire wrote:How much oversize are you wanting to go?
yup. 0.5mm to be realistic. Toyota do have 0.5mm oversize piston for 7AFE? 7AFE stock is 81mm rite?
normality78
