wud it make any difference having the air filter close to the throttle bodies rather then down near a headlight?? does length matter??? (of the intake that is)
Cheers - Luke
KinLoud wrote:Aim to have your throttle body to airfilter distance similar to the factory distance. If it's a bit longer it shouldn't hurt too much.
ROBODISCO_20v wrote:Thats way too close. You'll loose power/throttle response
l1ttle_d3vil wrote:KinLoud wrote:Aim to have your throttle body to airfilter distance similar to the factory distance. If it's a bit longer it shouldn't hurt too much.
umm...how does having the air filter closer than factory effect things? good or bad? ...and how close is too close?![]()
e.g:
thaphatty wrote:redmist sig.
