20v and ae85 rev cut?
Postby Meadzy » Mon Apr 23, 2007 9:56 pm
my cars a ae85 with 20v silvertop, iv been lead believe these engines are ment to rev to about 8200-8500?
i raced at the drags on friday and hit some sort of rev cut at 7900.. unsure if its the factory rev limit its just it didnt sound like a normal limiter would, more like a fuel cut or something similar.
iv also read elsewhere about putting the silvertop into a previously non-efi car can decrease the rev limit due to the speed sensor or something. unsure if this is true or not?
is anyone able to shed a bit of light on this or is it purely normal?
thanks
hayden
"Keeping it true to the JDM"
J-Spec Group
http://jspecgroup.com/forums/index.php
AE86,200sx,EG6
Meadzy
Re: 20v and ae85 rev cut?
Postby Rick » Mon Apr 23, 2007 10:16 pm
Max power is approx at 7400rpm so no point reving to 8200-8500 and the rev cut is what you are experencing at 7900rpm.
If the speed sensor is not fitted in you car then the factory speed cut is now disabled.
Postby Ae92typeX » Mon Apr 23, 2007 11:11 pm
could also query the accuracy of the rev counter - not much between 79 and 82 - could easily be out that much
Ae92typeX
Postby KinLoud » Mon Apr 23, 2007 11:16 pm
If the factory setup AE101's with 20v's you will find that the factory revcounter over reads. i.e. actual revcut might be 7900rpm but revcounter might read 8300rpm.
Ken
Ham
021 408 863
Postby Alex B » Tue Apr 24, 2007 12:46 am
Dont auto ecu's have a slightly lower rev limit?
Postby Meadzy » Tue Apr 24, 2007 9:08 am
yep i know theres no more power over that but was concerned a bit as it felt more like a fuel surge or something similar. but yer could just be normal and its using a manual ecu.
also wouldnt know about speed cut..havnt gone that fast yet
J-Spec Group
AE86,200sx,EG6
Meadzy
Postby Mr Revhead » Tue Apr 24, 2007 11:17 am
you on toymods?
ill have a look again bu t i read a thread recently there with the same issue
turns out theres a wire in the dash that if not connected properly lowers the rev limit
Postby frost » Tue Apr 24, 2007 3:03 pm
i had the same problem with my blacktop, it was the speed signal not being hooked up, u can get a speed signal from the ae85 dash, i have a pic of it,
failing that then check the codes and see what comes out,
Postby deaf_rattle » Tue Apr 24, 2007 3:06 pm
pyro_sniper2002 wrote:Dont auto ecu's have a slightly lower rev limit?
my auto ecu constantly sees 8300rpm, sometimes as high as 8450 :lol:
but thats about as useful as a power tornado intake
Postby slighty_sykotic » Tue Apr 24, 2007 3:21 pm
frost wrote:i had the same problem with my blacktop, it was the speed signal not being hooked up, u can get a speed signal from the ae85 dash, i have a pic of it,
This guy will be right.
If you havnt got the speed sensor hooked up, lowers revlimit in silvertops (and does far worse in a blacktop...).
Find a 20v factory car, and sit still in netural and rev it up to hit revcut, have a look where it cuts, and then go do it while driving. Fair bit of a difference.
--Sykotic
slighty_sykotic
Postby Meadzy » Tue Apr 24, 2007 5:06 pm
not on toymods but i randomly read something on twincam.net or some random site bowt speed sensor not being connected. ill have a talk with reo at tama autos as he wired my car up
J-Spec Group
AE86,200sx,EG6
Meadzy
Postby Zak » Wed Apr 25, 2007 9:50 am
If you don't have a speed sensor hooked up, I'm pretty sure the diagnostics mode doesn't work.
Zak
Postby deaf_rattle » Wed Apr 25, 2007 10:04 am
im sure it would work, it would just give you a code for faulty speed sensor
Postby vvega » Wed Apr 25, 2007 11:12 am
speeds sensor
been there doen that
vvega
Postby johntramp » Thu Apr 26, 2007 12:51 am
i made a 555 circuit to fake the speed input. worked well as otherwise the ecu stayed in limp mode or whatever you want to call it, so no vvt etc
johntramp
Postby Meadzy » Thu Apr 26, 2007 9:14 am
ok thanks guys for the help! :wink:
J-Spec Group
AE86,200sx,EG6
Meadzy
Postby IH8TEC » Thu Apr 26, 2007 9:29 am
ha, saw you at the drags, l was standing over by the honda's opposite you :oops: car look really tidy and did not too bad down the strip :D just thought i'd mention it, wasn't sure if you were on here or not
Postby Meadzy » Thu Apr 26, 2007 6:34 pm
haha oh yip with the ef's, yer 15.9 wasnt bad considering
J-Spec Group
AE86,200sx,EG6
Meadzy
Postby Meadzy » Sat Apr 28, 2007 6:41 pm
Anyone know which pin to connect it to?
J-Spec Group
AE86,200sx,EG6
Meadzy
Postby deaf_rattle » Sat Apr 28, 2007 7:29 pm
15.9? isnt that pretty slow for a lighter car with a 20v in it? my mate got a 15.7 in his ae101.
sounds like something's not quite right
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
