slydesigns wrote:Those in the points have right of line in booking a seat followed by those who raced in the current round but not in the one before, followed by Toyspeed members new to the series then lastly your mates/enemies/drug dealers or pimps.
Lith wrote:Yeah I didn't think it was that bad considering. Richards cart being destroyed probably made them grumpy.
the_daytona_guy wrote:yea as i say i prefer to let it go, but we have to slow you down when your coming 2 or 3 wide into a tight corner just incase a guy in front spins and causes a big crash, but we should put more trust in you guys especially as you all are quite talented go kart drivers
U*R*A*B*U*S
U*R*A*B*U*S
Loudtoy wrote:Fair enough i suppose, i know a couple of times we were 3 wide coming into the sweeper and there really is only enough room for 1 1/2 carts on the exit to that corner. All good tho now that the left side of the split section is nearly as fast as the right there's a good oportunity to pass there. Maybe something to add next time to the breifing is if someone is on the inside of you by more than 1/2 a cart they have right of way, not the right to push the guy on the outside into the tires but the guy on the outside shouldn't try and squeeze the inside line either!
Loudtoy wrote:the_daytona_guy wrote:yea as i say i prefer to let it go, but we have to slow you down when your coming 2 or 3 wide into a tight corner just incase a guy in front spins and causes a big crash, but we should put more trust in you guys especially as you all are quite talented go kart drivers
U*R*A*B*U*S
Return to Palmerston North / Central North Island Region
