exhaust manifold heat + wires = ??
Postby AE82 FXGT » Thu Apr 26, 2007 7:41 pm
Hey all,
I'm thinking of getting some oil pressure and oil temp gauges.
Looks like the best way for me to set it up would be through an oil filter sandwich plate.
So that I can remove them if need be.
Only thing is as the oil filter on 4ages is right near the exhaust manifold, would I have big issues with the wires (as I plan running electrical gauges)?
AE82 FXGT
Postby big_boy » Thu Apr 26, 2007 7:55 pm
not if you use the correct wireing & covering
for sale EE90
big_boy
Postby tHE _mEXICAN » Thu Apr 26, 2007 7:56 pm
Should be fine just as long as the wires are insulated well and are away from the exhaust. Your oil pressure sender should be right next the oil filter, well it is on the 4agze's so i'm guessing it'd be the same on a 4age.
Might just be an idea to get a reloacting kit and T off from there as you could eventually put in an oil cooler if you wanted.
RIDES:
73' KE25 SR Coupe (LONG TERM PROJECT)
Soon to be 4AGTE monster powered
tHE _mEXICAN
Postby TRD_ZERO » Thu Apr 26, 2007 8:02 pm
Yeah i got an oil cooler and my oil pressure is t'd off it..........its a good excuse to get an oil cooler :D
TRD_ZERO
Postby AE82 FXGT » Thu Apr 26, 2007 9:38 pm
tHE _mEXICAN wrote:Should be fine just as long as the wires are insulated well and are away from the exhaust. Your oil pressure sender should be right next the oil filter, well it is on the 4agze's so i'm guessing it'd be the same on a 4age.
I've got a gze. So your talking of the factory one?
I haven't looked around the area yet to be honest.
AE82 FXGT
Postby strx7 » Thu Apr 26, 2007 11:03 pm
a rangi cheap trick that works is to simply put insulation tape around the wires, then put some insulation tape around them upside down so its sticky then put some TINFOIL around it. works a treat
Postby IH8TEC » Thu Apr 26, 2007 11:44 pm
strx7 wrote:TINFOIL
man that is rangi :lol:
Users browsing this forum: Bing [Bot] and 12 guests
