[b|indsp0tt] wrote:.I highly doubt he has a dyno graph for his 4AGE but I'll ask anyways.And no he's not from Rotorua,he's from Auckland.
Maybe it was measure with a DynoButt seat-of-the-pants-o-meter.
matt dunn wrote:[b|indsp0tt] wrote:.I highly doubt he has a dyno graph for his 4AGE but I'll ask anyways.And no he's not from Rotorua,he's from Auckland.
IH8TEC wrote:someone had to say it, if you want a high revving 4cyl powerful NA, buy a honda vtec motor for as cheap as you boss is saying.
i went for a ride with deanis in his crx, has 151kw roughly atw, and with an extra odd 150-160kgs, the thing still hauled buttocks to just under 9000rpm. impressed me alot.
nzae86 wrote:Yeah,thats what I'm thinking.He said it cost him $6k to build his old 4AGE (220HP),without any labour charge because he did it himself.
Well I must be doing something wrong the engine in my current rally car has had more than that spent on it and it is only a good honest 100kw (135bhp) at the wheels . My atlantic engine will be about 3 - 4 times the cost and I am hoping for about a reliable 220hp at the flywheel. The head work alone on the atlantic engine would probably amount to 6k! and this engine is the real deal not just "atlantic spec"
ROBODISCO_20v wrote:nzae86 wrote:Yeah,thats what I'm thinking.He said it cost him $6k to build his old 4AGE (220HP),without any labour charge because he did it himself.
Don't mean to sound rude but most black tops with a mild tune will put out over 100kW. (mine is) May not be as reliable as your engine under race conditions though.
Mr Revhead wrote:ROBODISCO_20v wrote:nzae86 wrote:Yeah,thats what I'm thinking.He said it cost him $6k to build his old 4AGE (220HP),without any labour charge because he did it himself.
peak hp is a bollox way to decide how good an engine is
look at the torque curve
Mr Revhead wrote:peak hp is a bollox way to decide how good an engine is
RedMist wrote:What rough copy in the fact that its got 4 valves per cyl and double overhead cams?? The bore, stroke, obviously cc, compression ratio, castings, the included valve angle, the port angle, the cam tray, almost everything is different between the two. I have no idea where the copy quote came from, but I cant see any resemblance.
There may have been some influence, but a copy most certainly not.
vvega wrote:lol and here comes the time old arguement
its almost as bad as the roots of teh bda = kent motor
and that teh lotus engine is dirivative of the teh kent
Users browsing this forum: Bing [Bot] and 24 guests
