t50 and support brackets
Postby fxgt race » Mon Apr 30, 2007 12:44 pm
as we a doing smallport into rwd,is it nesssary to put the two lower support brackets on or a the 4 bolts that hold it to the block sufficient.I know that these brackets would have to be modified to fit around the new engine mounts.
fxgt race
Postby KinLoud » Mon Apr 30, 2007 3:54 pm
I know of a friend who raced on Taupo 6 or 7 seasons with 4age T50 without using the braces. Didn't have a problem... That said fit them if you can - I guess Toyota used them to help get reliability (3 or 400,000 km or so).
Ken
Ham
021 408 863
Postby fangsport » Mon Apr 30, 2007 4:48 pm
i have been infomed to use them where practical. seemingly they reduce bellhousing flex and reduce premature failure of the input shaft bearings.
fangsport
brackets
Postby fxgt race » Mon Apr 30, 2007 9:26 pm
cheers for the info will modify and put them back on
fxgt race
Postby l1ttle_d3vil » Mon Apr 30, 2007 9:40 pm
i haven't had mine fitted in the 18 or so months my cars been on the road, never had problems. i tried fitting them but part of my steering rack ended up hitting them...
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
