a ct26 bigger than a ct20b?
http://www.trademe.co.nz/a.asp?id=97570915#qna
read the questions
groupagt4 wrote:a ct26 bigger than a ct20b?
read the questions
groupagt4 wrote:wel if you read the questions you would be able to see that bigger means more flow or more capable of making a efficient 18 psi.basically the guy is saying a ct26 is beter than a ct20b
The CT20 is bit smaller then the CT26 az the Ct26 has power range 350-395hp running at 18psi max which is capable if engine can handle and other mods like ecu and fuel pump is changed.
