Strange 20V behaviour
Postby Blackstripe » Tue May 15, 2007 2:10 pm
Hey guys my Silvertop (AE101 Trueno) runs fine except the engine is sometimes a bit "stall-ish" at idle. For example, if I press the throttle a tiny bit, just a tiiiinsee bit the revs will actually drop and the engine will shake before rising back up. Under driving conditions its fine and it goes hard up top when given some gas. My mechanic says its probably the AFM actin funky. This one time it stalled in traffic though but its probably just my crappy driving or something. Anyway the spark plugs are sweet, so are the leads, so Im guessing its either some clogged injectors or the timing being a tooth off. (Or the AFM)
Also sometimes when Im driving and I change gear or put my foot on the gas I can hear a quiet audible backfire (Little pop sound). My old bluetop used to do this but it had a quite restrictive exhaust system the silvertop has a 2.25" so I was thinking that would be enough to relieve back pressure. Guess not.
Oh yeah, one more thing, I didnt like the pod filter sitting behind the battery so i moved the radiotor overfill thingy and with some elbow grease i managed to get the pod up closer to the radiator on the left side of the battery. Is this a good idea? Im a little concerned because the intake pipe is at a steeper angle so I might have done more harm than good, but it probably doesnt matter eh :P
Cheers dont bother reading the whole thing im only concerned about the strange behaviour at idle.
Thanks :D
I live my life 1000RPM at a time. Nothing else matters, not the blown piston rings, the wasted distributor, the popping oil cap and all that other stuff. For those 8000RPM or more, im free.
Blackstripe
Postby deaf_rattle » Tue May 15, 2007 2:12 pm
check timing
Postby Blackstripe » Tue May 15, 2007 2:55 pm
cheers will do
Blackstripe
Postby AceSniper » Tue May 15, 2007 3:17 pm
yea timming, my blacktop does it atm, runing a link... pritty sure my cambelt is streached need to replace it
AceSniper
Postby bluemaumau » Tue May 15, 2007 9:00 pm
interesting that you say that ace, can a cambelt be tightened(i.e a motor that keeps being pulled down, assembled, pulled down etc etc) to much?
or should you look at replacing it after every so often?
Postby deaf_rattle » Tue May 15, 2007 9:47 pm
thats what the tensioner is for
Postby bluemaumau » Tue May 15, 2007 10:03 pm
yes but surely tensioning it every time its going to stretch the belt
Postby AceSniper » Tue May 15, 2007 11:52 pm
dont know if my tensioner is fualty or the belt is just mega streached, its abit losse for my liking, engine still runs damn well, so the rpm drop might be ecu/tune related also but Id go more for the belt issue
AceSniper
Postby Dell'Orto » Tue May 15, 2007 11:52 pm
Motors often have a gas auto tensioners for cambelts, or at least a tensioner bearing.
Postby tianporn » Wed May 16, 2007 3:56 pm
Yeah you should check the timing. May be off a bit
tianporn
