Strip nd Screw
Strip nd Screw
Postby ke2nv » Fri May 18, 2007 12:37 am
Theres a screw holding in the headlight surround on my car, the head of which is completely stripped. You put the screwdriver in and it just spins, really annoying :evil: . Does anyone know an easy way to get these ba5tards out?????
Adamal wrote:Aww Bae, you jus come up to a corner, and smack it back in second gear, and bounce it off da red line and turn bro! Then you stick your arm out the window and go "CHUR BAE!!!"
World's best description of "How To Drift".
ke2nv
Postby FouRacer » Fri May 18, 2007 1:04 am
Couple of ways if you cant get the mole grips onto it, drill it if you can get a drill in, either drill it right through or drill a small hole in the centre and get an EZ out into it. Other than that you'll probly have to weld the end of a small bar to it, 20 - 30mm long. Shouldnt be too much of a mission. Usually though the right size screwdriver, pushed hard enough, will do the trick. Good luck bro. :evil:
GT-FOUR Racer
FouRacer
Postby ke2nv » Fri May 18, 2007 1:10 am
hmm yea the grips wont work, theres not enough surface area to grab on to. Ill try drill it, hopefully that should do it. Cheers man
ke2nv
Postby Stealer Of Souls » Fri May 18, 2007 10:20 am
Jaycar sells a screw extraction kit... Kinda expensive but if it works...
'86 AE85.5 Levin
Stealer Of Souls
Postby Crucible » Fri May 18, 2007 1:26 pm
shouldnt need to get too carried away, just use side cutters
Crucible
Real Life Mechanic
Postby evil_si » Fri May 18, 2007 1:37 pm
as edyn has said, use side cutters, make sure they bite into the outside of the screw head nice and tightly and it shud undo!!
evil_si
Postby Ae92typeX » Fri May 18, 2007 6:02 pm
does it screw into metal or a plastic bung? Ive come accross some that screw into plastic, and it is the plastic, not the screw that has been stripped. Either a 'safe' yank or squezing the plastic while screwing worked.
Can you get behind it, or is it in a box section?
Ae92typeX
Postby ke2nv » Fri May 18, 2007 10:26 pm
sorry, i didnt phrase my first question very well :oops: The head of the screw is stripped, meaning the X on the head of the screw is now rounded out to a circle.
ke2nv
Postby Ae92typeX » Sat May 19, 2007 12:31 am
ah, as above then, drill...unless you can hacksaw a groove for a flathead (+ soak in crc first if all metal)
Ae92typeX
Postby evil_si » Sat May 19, 2007 1:10 pm
ke2nv wrote:sorry, i didnt phrase my first question very well :oops: The head of the screw is stripped, meaning the X on the head of the screw is now rounded out to a circle.
use a pair of side cutters,
make the jaws bite into 2 points 180' apart, if that doesnt work then look at drilling out etc.
evil_si
