going from c52 to e51
Postby gasman » Mon May 21, 2007 7:45 pm
wanting to get a aw11 4agze e51 gearbox to fit my blacktop 20v which currently has a c52. will i need to get a new flywheel and clutch setup to make it work?
im guessing i will need drive shafts and cv joints but from what car?
and i wont need to get new hubs right?
"What can possibly go wrong?"
gasman
Postby TRD_ZERO » Mon May 21, 2007 8:44 pm
OK this is from what i understand...............The blacktops come with the c56 box, the silvertop ones came with the c52 and some with the c56. You should stick with your box being a c52 or 56 as the c series have better ratios. Unless you are going to turbo your car or something around those lines im taking the same rout myself but im turboing my engine so wont put my e51 box in untill i get it going.
Yes you will need the shafts and cv to fit.......you shouldnt need to change your hubs. For the clutch i just went to trade parts and told them i wanted a clutch plate that would fit in the blacktop flywheel and be splined for the e51 box and they handed me a exedy unit. Better to go this way as you get to keep the lighter flywheel.
TRD_ZERO
Postby gasman » Mon May 21, 2007 9:46 pm
yea going turbo and ive already blowen up one c52 with the blacktop in na form already so im not too keen on running one in turbo form
gasman
Postby flygt4 » Tue May 22, 2007 5:12 pm
how much power are you planning on making?
do you like to shift smoothly? the e series boxes are all pretty old, and nearly all of them have stuffed synchros. if you're prepared to rebuild a box properly that can be sorted tho. also ,the ratios are quite long and theres a huge gap between 2nd and 3rd gear. bazda ended up using a mix/match selection of ratios from mr2 and corollas to help keep the ratios closer and improve his 1/4 mile time.
the advantage is they are pretty strong internally, but if you're going to be less than 150wkw then i reckon the c series is the way to go anyway. i know of c series gearboxes that have lasted well behind a turbo'ed engine with only a little bit of mechanical sympathy.
flygt4
Postby gasman » Tue May 22, 2007 7:09 pm
planning for about 210kw-230kw
got my home made launch controller going, so may flatshift between gears at the drags. but that is how i stuffed my my other c52 box but that already had a massivly fooked sinchro already.
gasman
Postby gepsk8 » Tue May 22, 2007 7:19 pm
lol, i blow mine c52 up with standard smallport 4age.
gepsk8
Postby no_8wire » Tue May 22, 2007 7:39 pm
you do realize you need to mod the box to get it to work on a fwd aye?
no_8wire
Postby gasman » Tue May 22, 2007 7:56 pm
no_8wire wrote:you do realize you need to mod the box to get it to work on a fwd aye?
yea. need to drill a hole and something else.
anyone know what that something else is?
gasman
Postby 20v_rollaboy » Wed May 23, 2007 12:34 am
Ive just done this to my car. But I used a box from a ae101 so didnt need modding.
Needed new flywheel, clutch and pressure plate, and the driveshafts.
Didnt have to change hubs, and Im still using the same slave cylinder.
20v_rollaboy
Postby bluemaumau » Wed May 23, 2007 1:59 am
how are you finding it ryno?
gear ratios ok?
Postby no_8wire » Wed May 23, 2007 8:34 am
need shifter parts from both fwd and also aw11 box to get it to work
http://www.padandwheels.com/mr2/blacktopproject/day13/c56.html
has the info for a c52 box on how to convert
no_8wire
