wheel studs
wheel studs
Postby sk1dlet » Tue May 22, 2007 11:30 pm
hey people im getting a headache fitting sum new wheel studs in
they seem to be a bit tighter than the old hilux ones and also the splines on them seem to be finer and more of them.
would these studs be not correct or what wud be the easiest way to get these puppies fitted any ideas wud be welcomed
dylan
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby Mr Revhead » Wed May 23, 2007 11:41 am
sounds like they are not the right ones....
are you changine the originals for longer ones?
if so you may need to go into your local dealer and match splines etc
Postby Charged1 » Wed May 23, 2007 3:23 pm
Hi while we are on the subject of studs , I have just brought some 25mm spacers for the rear of my ST202 Celica but the factory studs stick to far through the spacers so the wheel rests on the bolts rather than flush up against the spacer , can the studs be cut shorter or will i need to buy some shorter ones ? Thanks
Charged1
Postby TOYROTA » Wed May 23, 2007 5:27 pm
wrong studs by the sound of it dylan. take them to toyota or repco in matamata
Curre3nt rides-
1982 starlet kp61 4 door (in panel shop getting bare metal resto)
1980 tt132 corona wagon 3t t40 (daily doomsday machine)
TOYROTA
Postby sk1dlet » Wed May 23, 2007 7:12 pm
yea i thought they mite have been cheers
98 RS200 ALTEZZA
sk1dlet
Postby Emz » Fri May 25, 2007 9:49 am
Charged1 wrote:Hi while we are on the subject of studs , I have just brought some 25mm spacers for the rear of my ST202 Celica but the factory studs stick to far through the spacers so the wheel rests on the bolts rather than flush up against the spacer , can the studs be cut shorter or will i need to buy some shorter ones ? Thanks
I had spacers with my old mags and when I changed them I found that my wheel studs had just been sawn off to sit flush with the spacers. Didnt seem to cause any problems.... But now I'm not using the spacers and my new mags are held on by sweet FA so im trying to find some new studs also.
'97 Supra RZ - Click Here! | Discussion thread - Click Here
Emz
Miss Supra Princess
Postby Charged1 » Sat May 26, 2007 9:33 pm
Emz what size wheels and tryes you running , I just want to fill out the guards that why i was going use spacers , but would rather not if there is another option , Thanks
Charged1
Postby Emz » Tue May 29, 2007 4:31 pm
Charged1 wrote:Emz what size wheels and tryes you running , I just want to fill out the guards that why i was going use spacers , but would rather not if there is another option , Thanks
The front are 265/30 ZR19 and the rear are 305/25 ZR20.
Emz
Miss Supra Princess
Postby Defective » Tue May 29, 2007 4:50 pm
Emz wrote:[
holy crap. thats some serious size rubber 8O 8O 8O
Defective
Postby Bling » Tue May 29, 2007 6:16 pm
Emz wrote:
Charged1 wrote:can the studs be cut shorter or will i need to buy some shorter ones ? Thanks
swap studs? :lol:
note: this theory does not take into account the number of studs each car has :lol:
Postby MR2SIK » Tue May 29, 2007 6:38 pm
Be careful there, apparantly at WOF checks they check how much of the stud is going through aftermarket wheels, I think it has to have at least 6 threads showing without the nut.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby Emz » Wed May 30, 2007 9:37 am
Yeh thats what I thought, I took it for a WOF last week and they looked like they were doing something with the wheels, but they must not have checked coz I passed. I think I've only got 3 turns of thread on each wheel stud. But I'm more worried about the safety of the car, not sneaking through a WOF check
Called Toyota and they quoted $6.60 + gst per stud for new ones. They didn't need to view a sample or get engine/chasis numbers either, just told me over the phone what I needed for a supra. So I'll be ordering those as soon as payday rolls around... seeing as I need 20 of the freakin things *sigh*
Emz
Miss Supra Princess
Postby Emz » Wed May 30, 2007 9:39 am
swap studs? :lol:
LOL
Well, I need 20 long ones and I have 20 short ones.... how many you got Charged1?
:lol:
Emz
Miss Supra Princess
Postby Emz » Wed May 30, 2007 9:40 am
Defective wrote:
Emz wrote:[
Yeh, anyone wanna be my tyre sponser? :/
Emz
Miss Supra Princess
Postby Charged1 » Thu May 31, 2007 11:54 am
Emz I only have spacers for the back yat to get front ones so will just have the ten off the rear , cheers
Charged1
Postby Emz » Thu May 31, 2007 1:10 pm
Charged1 wrote:Emz I only have spacers for the back yat to get front ones so will just have the ten off the rear , cheers
hehe probably not a good idea to swap anyway.
The previous owner of my car did some wierd stuff with the old mags, on the front and rear LEFT side of the car they put bolt on 50mm spacers but on the front and rear RIGHT side of the car they had a 50mm bolt on spacer PLUS a 30mm loose spacer... dont know what was going in with that lol.
Emz
Miss Supra Princess
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
