Brake disc coversion help! spongy peadal
Postby samham » Sun Jun 03, 2007 8:03 pm
I have replaced the rear drum brakes on my ke25 with discs and calliper of te71, the car has brake bias adjustment fitted to. And pedal box.
they are all fitted and do stop the car but after bleeding 4 times the peddle almost goes to the floor, if you pump the pedal it it does go hard???
The calipers and pads seem to be fitted squarely, I operated the brakes on the discs and then tacked the brackets, so I'm guessing? its not a issue with that.
Am I missing something is there something that I need to change etc.
any ideas appreciated
cheers, sam
Drive it like you stole it!
disclaimer: do NOT steal a car;-)
samham
Postby slighty_sykotic » Sun Jun 03, 2007 8:41 pm
Right caliper on the right side?
If you got them around the wrong way you will have pockets of air in the top of the calipers that you can not remove with the bleed nipple.
slighty_sykotic
Postby samham » Sun Jun 03, 2007 10:06 pm
Im pretty sure I have them on the right sides, but I will double check.
Was just thinking though I have mounted them parallel to the ground on top.
Do they need to be up down, at a right angle to the ground?
Could there possibly be a air bubble?
Maybe i could vacuum bleed them?
samham
Postby KinLoud » Sun Jun 03, 2007 10:46 pm
If the bleed nipple isn't at the top...
Undo one bolt and rotate caliper until the nipple is at the top,
If the pads are clear of the disk then put some wood or something to stop a piston popping out.
Bleed the brakes, then bolt the caliper back in the correct place.
Ken
Ham
021 408 863
Postby AE82 FXGT » Sun Jun 03, 2007 11:58 pm
Can you bleed the proportioning valve?
AE82 FXGT
Postby Ae92typeX » Mon Jun 04, 2007 9:34 am
Im assuming the master cylinder has enough capacity to operate the new brakes? (on some cars this has to be changed also)
Ae92typeX
Postby sleeektoy » Mon Jun 04, 2007 9:59 am
check the disc runout (wobble) - if a disc is even slightly out of running true it pushes the pads/pistons back a bit causing more fluid/pedal travel to pump the pistons back out. If it happens with the car stationary then it is more than likely an air leak or bubble
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby frost » Mon Jun 04, 2007 5:54 pm
does the ke25 have brake booster? what size master are you using? you may need to upgrade to the 13/16 master same as the te71/ae86
Postby samham » Mon Jun 04, 2007 7:46 pm
Just had a look today, I think? I have ruled out a air bubble, I did bleed them with the nipple at the top. No change.
There is a master cylinder for the back and one for the front from what I can see, just behind the pedals, and the bias adjuster changes the stroke on the cylinder push rod things, if that makes sense. There is no booster.
When looking at the brakes on one side closer today I did notice the inside pad that touches the piston does not seem to be touching the disc evenly? I'm not sure how this could be as the other pad is fine?
Thanks for your comments so far!
samham
Users browsing this forum: No registered users and 26 guests
