strx7 wrote:there is no point putting and E series box behind a 3SF engine. killing synchro's aren't a gearbox strength issue, I'd suggest working on your gear shifting technique before you try 'fixing' the issue by putting in a massively overkill gearbox.
darkwolf wrote:Also if any has an approx price I should be looking at for a good one that would also be appreciated.
strx7 wrote:if you brought it from a dismantler, and the synchro's were poked you could have taken it back
darkwolf wrote:strx7 wrote:if you brought it from a dismantler, and the synchro's were poked you could have taken it back
Understood, but due to time I couldn't. Still not answering any of my questions about whether the E-153 is likely to fit, 6 speed, price etc.
SUBARUCONVERT wrote:
6 speed no, to fit a E-153 to a ST171 u have to change the shifter to the back side of the box, run a turbo clutch, and run GT4 halfshafts, not worth the bother for ur power level
