Power Gains for a 20v Blacktop
Postby L0rolla1 » Wed Jun 06, 2007 12:47 pm
doesnt help i dont speak/read aisan. did he get the off this site?
CURRENT RIDE:96 lorolla wagon with al the bells and whistles
PREVIOUS RIDE: EP82 GT Starlet
1ST CAR: 1985 toyota trueno notchback
L0rolla1
Postby Calvin » Wed Jun 06, 2007 5:32 pm
L0rolla1 wrote:doesnt help i dont speak/read aisan. did he get the off this site?
I recommend "Japanese for Dummies"
Calvin
Postby 20v_rollaboy » Wed Jun 06, 2007 10:31 pm
No I didnt get them from that site. I found a BZ-R that was written off and managed to get these off it. Only cost me $100, and i think its well worth it :D Engine note changes at 3000rpm, and can feel the difference aswell.
And no, I dont have a black-top, have silver-top.
20v_rollaboy
Postby Matty104 » Thu Jun 07, 2007 9:09 pm
will putting tubes on each throttlebody with a filter on each do much?, and that will need a new ecu , etc, am i right?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby TRD_ZERO » Thu Jun 07, 2007 9:27 pm
Its all debatable what performance gains or losses you will get from putting tubes on the individual throttle bodies. Makes a great sound though. And NO you wont need an aftermarket computer for that.
TRD_ZERO
Postby bluemaumau » Thu Jun 07, 2007 9:37 pm
blacktop wont, silvertop will, or you could wire in a blacktop loom
Postby Matty104 » Thu Jun 07, 2007 9:56 pm
what about the map sensor, or what ever it is?, do i need to attach that to anything?, its on a blacktop,, I can make the tubes up at work and flanges, the only thing i will need to buy will be the filters, what length should they be?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Calvin » Thu Jun 07, 2007 10:00 pm
Since you have a blacktop your engine is map sensored and you dont require a Air flow meter (AFM). That means you can do this without changing the standard ecu.
Calvin
Postby Bling » Thu Jun 07, 2007 10:43 pm
when I tested my blacktop with a "butt dyno" its faster with stock intake in place.
However, open trumpets (with filters) sounds nice! and when you change back you get a nice increase in performance :lol:
Postby RedMist » Thu Jun 07, 2007 11:17 pm
BZG|Bling wrote:when I tested my blacktop with a "butt dyno" its faster with stock intake in place.
Now thats substancial. I wonder how well calibrated your butt dyno is, as induction roar generally creates substancial butt dyno power. Mr Helmholtz agrees with you, removing the stock airbox removes power.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Matty104 » Fri Jun 08, 2007 7:40 am
so better off to leave the stainless intake with pod, which geta better flow because there is another pipe directing cold air from the groung to the cone of the pod
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby TRD_ZERO » Fri Jun 08, 2007 5:08 pm
Matty104 wrote:so better off to leave the stainless intake with pod, which geta better flow because there is another pipe directing cold air from the groung to the cone of the pod
Yeah thats right just leave it
TRD_ZERO
Postby Cakky » Fri Jun 08, 2007 5:51 pm
distrb done a back to back dyno with the quad throttle bodie chamber on and with it removed he made 3kw so yeah lol
Cakky
Postby johntramp » Fri Jun 08, 2007 7:29 pm
What does Hermann von think about a set of longer trumpets like seen on many RWD 4ages?
johntramp
Postby Distrb » Fri Jun 08, 2007 8:21 pm
Cakky wrote:distrb done a back to back dyno with the quad throttle bodie chamber on and with it removed he made 3kw so yeah lol
yeah, but i didnt have a stock setup though... so might be a different result for those that do..
Distrb
Regular Poster
Postby ROBODISCO_20v » Sat Jun 09, 2007 3:15 pm
johntramp wrote:What does Hermann von think about a set of longer trumpets like seen on many RWD 4ages?
Supposedly the longer the trumpet the lower in the rev range it will increase power & vice versa with shorter ones. I have 40mm ones on my bkl top & it screams from 7 til the cut around 7800. In hind sight i probably should have gone a little longer for street use, but sounds cool when you've overtaking someone in 3rd gear on the open road.
Any thing is better than the factory trumpets in my books. (I still have the factory plenum & intake pipe with a HKS pod filter)
ROBODISCO_20v
Postby Matty104 » Sat Jun 09, 2007 5:22 pm
so robodisco you still have all the factory plenum etc, just changed the rubber trumpets with other ones?[/quote]
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby AceSniper » Sat Jun 09, 2007 6:39 pm
mines the same airbox, with cold feed runing Imec trumpits
AceSniper
Postby Matty104 » Sat Jun 09, 2007 6:57 pm
so just change the rubber ones with strait ones?
'Tron E30 Massif
89 BMW 325sci
Matty104
