Stealer Of Souls wrote:I might be mistaken...
But 4ga is approximately the same as 35mm...
4ga is about 22m^2
neo wrote:gepsk8 wrote:thats the thing u cant put a fuse for the battery cable to starter, cause it draws to much current, biggest ever car fuse i've seen is 425amps, which might work in good conditions but would blown as soon as u got a cold start or flatish battery.
Dude your doing something wrong.
I have a 120amp circuit breaker on the 4ga lead coming off the battery in the racecar and it doesnt trip. Hell I had an 80amp circuit breaker on the bettery in my old mini which had a direct drive starter and that never blew either.
Just ensure your using good quality oxy free cable , and remember to match it with the earths / grouding points!
gepsk8 wrote:well like any good auto sparky will say u cant fuse the battery to starter wire when u put battey in the boot u can have up to a 7m or 8m cable depending on the car and way u route the wire, u havent no problems yet, wait till the starter gets tried or battery gets a little flat, then find out who laughing then,
gear reduction start u will get away with small cable but it not worth the risk for lossing ur car.
big_boy wrote:just for arguments sake i just went & tested mine with an inductive current meter
motor= 5M-GE with a compression of 180psi ish give or take 5
starter = is an up rated from factory ND rated at .9kw at motor & 2.7kw at final gear
battrie is otpma red top 850cca 1000ca
cranked for 8 seconds with a voltage of 13.2 V.D. under crank was 0.2V giveing me 13V & CURRENT OF 118.1A max
tryed on an old NS70 battrie witch was holding 11.9V V.D. under crank was 2.6V giveing me 9.3V at the starter & CURRENT WAS 133.3A
so i would get away with a fuse
also a EE90 with factory starter draws 57.6A at 11.6V
id be supprised if any car draws over 150A witch is a breaker readley advable
gepsk8 wrote:Seeing as fuses can operate up to twice their actual rating, yea right!!
