Emperor wrote:20B NA tuned haha
Mr Revhead wrote:basicly all i was doing was trying to sort a supply of w5# bits to make it viable to run 3sge/4age and w/t boxes.
didnt get very far as the aforementioned mazda pacakge was just too good.
as much as id like to see a toyota engine in it, i reckon the mx5 bits would be the way to go.
Loudtoy wrote:Question how much will the chevron without motor weigh in at?? I would suggest that the bike motor - all the beams powered cars i have been in haven't really impressed me all that much.
I say if it's around 600 without motor and box go with bike bits and special reverse gear setup wich i thing you can get from quaife - ask the star car guys who supplys theres. if its closer to 800 without motor perhaps a look at the 1800's that power the celica's would be a good idea altho expensive when you can pick up a 1300 bike motor and box and electrics for about 4k then the quaife reversing unit for another 2 and jobs right, 160 odd rwhp huge redline + if you ever want to figure out what a high speed forklift would handel like you have 6 reverse gears
fangsport wrote:Loudtoy wrote:Question how much will the chevron without motor weigh in at?? I would suggest the bike motor - all the beams powered cars i have been in haven't really impressed me all that much.
have you seen Tony McConachy's Busa KP rallycar? seems to have surprising amounts of torque and a redline that sounds like an F1 car. a kp would be heavier than most kitcars.
is Tony M aware of this? jump on utube and search for 'hayabusa starlet', and then try and tell us they won't work??? the poms have been fitting to anything and everything they can, unless the MSA bans them.Volodkovich wrote:Weight is a big problem for bike powered cars. Start going over the intended weight of bike plus two riders (380kg for gsxr1300) and you'll wish you had gone for a motor with more torque and a car clutch and gearbox...
Volodkovich wrote:not saying they wont work, read what i said. Simply saying they might not be the number 1 choice.
matt dunn wrote:Volodkovich wrote:not saying they wont work, read what i said. Simply saying they might not be the number 1 choice.
And i'm sure they're real easy to mate to a conventional driveshaft?
