deaf_rattle wrote:sweet then, dry sump it is![]()
i wish
Dude, just weld a flat metal sheet where the sump would have bolted on to the block. Problem solved.
i wish
me wrote:I was wondering what the cost of the Accusump and
35-40PSI electronic valve is?
them wrote:$238+gst in stock
barryogen wrote:I've flicked an email to cardwells.co.nz who seem to be somewhere in NZ that you can buy these things... quite keen really, seems like a good little bit of oil insurance.
neo wrote:I assume when the engine is turned off, all the oil squirts back in the sump, or is that what the valve is for?
barryogen wrote:and just got a reply to my pricing query...
Canton 3qt $328+gst, 2qt $298+gst
Mount kit if required $38+gst
and from above...
35-40PSI electronic valve - $238+gst
Have asked about group discount too...
neo wrote:I suppose you could tee in an oil pressure switch / sensor or the like to show what is in the canister.
I was just thinking, Wouldnt you be able to apply a similar idea to the fuel rail? (only thing being is the volume + pressures involved).
barryogen wrote:They were "less than keen" on a group buy.
Users browsing this forum: Bing [Bot] and 26 guests
