Roll Center Adjuster,what length for AE-85/6?
Postby Rick » Tue Dec 06, 2005 6:11 pm
I am going to make some roll center adjusters for my ae85 and would like to know what length to make them, is the length of the (RCAs) determined by how much you lower the car by? because I have seen kits for sale ranging from 20mm to 50mm.
Postby Low_Aa63 » Tue Dec 06, 2005 6:27 pm
hard out! what the hell do they do?
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
Low_Aa63
Postby Rick » Tue Dec 06, 2005 6:35 pm
Low_Aa63 wrote:hard out! what the hell do they do?
When you lower an AE86/85 etc the more you lower it, the more you affect the suspension geometry. lowering it can drastically change the front role center. To correct the front changes in geometry from lowering, the spacer helps to re-align the front lower control arms back to proper specs once your AE85/6 has been lowered.
Postby gdsup » Tue Dec 06, 2005 6:42 pm
those ones in the pics battle version ?
i would believe the theory would be to have them the same length as to what you have lowered the car, effectivly 'zeroing' it off, i would be tempted to use a offset/negative rca which will add track width and camber if doing this,
although im sure sean faithful will have his say on this :D
gdsup
Postby Low_Aa63 » Tue Dec 06, 2005 6:52 pm
so after you lower it you put those blocks in it and raise it back up??
The list so far
Low_Aa63
Postby gdsup » Tue Dec 06, 2005 6:56 pm
no they dont raise they car, they let the arm drop back to its original angle ( or close to), imagine that pic above if the rca wasn't there, the arm would be flat instead of on a downwards angle
gdsup
Postby Malcolm » Tue Dec 06, 2005 8:35 pm
yes, and if an arm is horizontal, any further suspension compression will cause camber to increase, to the point where you may end up with positive camber on the outer wheels going around a corner at speed - which would not be at all good
Postby rxtoy » Thu Dec 08, 2005 6:15 pm
what they said. if i were you i'd look at buying some from techno toy tuning in america, they make some quality gear for good prices. i made a set myself for my lancer because there was nothing around and its quite a hard job to do, even with having a milling machine and a lathe available.
website = http://www.technotoytuning.com/t3_site_ ... lates.html
they've got quite a bit of cool stuff available for old toyota's
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby beeker » Thu Dec 08, 2005 6:57 pm
rxtoy wrote:what they said. if i were you i'd look at buying some from techno toy tuning in america, they make some quality gear for good prices. i made a set myself for my lancer because there was nothing around and its quite a hard job to do, even with having a milling machine and a lathe available.
Matt
or locally
http://www.86factory.com/T3Cbrpltsi.htm
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby gdsup » Thu Dec 08, 2005 8:52 pm
gdsup
Postby Jebus » Fri Dec 09, 2005 10:29 am
By locally you mean twice the price of buying them yourself direct from T3, and a 4-6 week wait :roll:
Jebus
Postby Caveman » Fri Dec 09, 2005 6:31 pm
Are they road legal? Or do they need certification? Or are the a big no no for street?
Caveman
Postby CozmoNz » Fri Dec 09, 2005 6:45 pm
ive always wondered what those are for...
Rayne For President!
CozmoNz
Postby beeker » Fri Dec 09, 2005 10:57 pm
So how do you figure that ?
TechnoToyUS $70 = NZ$99.70 + freight = $120+
Ae86Factory NZ$130 including freight
both have probably the same shipment time.
06 RS4 Avant
beeker
Postby wde_bdy » Fri Dec 09, 2005 11:02 pm
beeker wrote:So how do you figure that ?
And being a legitimate business they also have to charge the GST that you may dodge with importing privately.
Callum
wde_bdy
Postby Jebus » Mon Dec 12, 2005 7:02 pm
Thier camber plates for example, are $70 cheaper landed here in NZ from T3 than 86Factory's prices, and take 4 days to get here.
Jebus
Postby beeker » Mon Dec 12, 2005 7:28 pm
Jebus wrote:Thier camber plates for example, are $70 cheaper landed here in NZ from T3 than 86Factory's prices, and take 4 days to get here.
and that assumes you dont have to pay gst or get stung with freight. For such a marginal saving, i would support the local guy. :)
06 RS4 Avant
beeker
Postby rwd_mayhem » Fri Jun 29, 2007 11:32 am
will a roll centre adjuster made to fit an ae85/6 also fit k/ae70?
current: 1975 Valiant Regel
rwd_mayhem
Postby d1 mule » Fri Jun 29, 2007 12:00 pm
maje offset ones i had some T3 negative camber on my one havt it overall 80mm increased track in 3.3 degrees camber on both sides. that being said i never had any issues with"bump steer" which is what they are ment to fix but after i installed them man it had good turn in :D
d1 mule
Postby johntramp » Fri Jun 29, 2007 1:15 pm
beeker wrote:i would support the local guy. :)
all he is doing is reselling them, not like he is in competition with t3.
johntramp
