KE20 Backseat help.........please
Postby ke2nv » Mon Jul 02, 2007 7:19 pm
I just CANT find how to take the backseat out of my KE20, not the bottom bit, but the backrest. Its probably easy, but i just cant find the bolts or whatever it is that holds it in. Can anyone help?
Adamal wrote:Aww Bae, you jus come up to a corner, and smack it back in second gear, and bounce it off da red line and turn bro! Then you stick your arm out the window and go "CHUR BAE!!!"
World's best description of "How To Drift".
ke2nv
Postby andyztouring » Mon Jul 02, 2007 7:52 pm
Just undo the bolts at the bottom,then lift the seat upwards,could not be any easier.
andyztouring
Postby l1ttle_d3vil » Mon Jul 02, 2007 9:12 pm
in my ke35 you unbolt the bottom (two bolts at the front of it).
then you can get at the two bolts at the very bottom of the backing, undo them then you slide the seat up. it sits on a couple of hook things, I had to smack mine really hard and maybe take the parcel tray out too...
thats for a ke35 but the ke20 would probably be simiarl...
Postby ke2nv » Mon Jul 02, 2007 11:00 pm
yeah it should be similar to a ke35, i hope! Ill try what you said tomorrow after work, i just couldnt find the bolts when i looked.
ke2nv
