Slap Car Audio??
Slap Car Audio??
Postby KiwiMR2 » Wed Jul 04, 2007 10:21 pm
These guy's any good? Would the be able to do a couple of A-pillar mounted gauges? If not anoyone reccomend anyone in Wgtn region?
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby ke70dx » Wed Jul 04, 2007 10:57 pm
Hmm bit monkeyish there. Do you need it fabricated or just installed?
ke70dx
Postby KiwiMR2 » Wed Jul 04, 2007 11:41 pm
ke70dx wrote:Hmm bit monkeyish there. Do you need it fabricated or just installed?
Have 2 gauges already installed....one is in a pod that is glued with what looks like silicon used in bathrooms to the a-pillar & the other is just sitting under that one the dash. Need a dual a-pillar pod & them put in it all nice & tidy :)
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby cogent » Thu Jul 05, 2007 12:46 pm
Got any examples of this? I got them to do my alarm in my AW11 MR2, mongoose M60g install + 2 door lock poppers + install for $500. They said it would be done by the end of the day and at 12.00 gave me a call to let me know they were having some trouble fitting the poppers inside the doors. I showed up at 5.00 when they close and it still wasnt ready, so they let me come hang out in thier workshop and chatted about car stuff while I waited. They stayed open by 45 minutes to finish my car off, which I thought was really good service.
No complaints of the work i had done there, and im getting another alarm in my RX7 next week from there.
cogent
Postby Mr Revhead » Thu Jul 05, 2007 1:17 pm
make sure the hook up the beeper so you know when the imobileiser has armed :wink: :P
Postby cogent » Thu Jul 05, 2007 2:14 pm
Mr Revhead wrote:make sure the hook up the beeper so you know when the imobileiser has armed :wink: :P
Imageshhh!
cogent
Postby KiwiMR2 » Mon Jul 09, 2007 11:34 am
What about Mag & Turbo in Newtown......thet capable enough to do it? Maybe I'd be better off buying the a-pillar pods & doing it myself.....I'm not sure what size the gauges are, do you measure front edge to edge or just tghe glass part?
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby Ard Righ » Mon Jul 09, 2007 2:10 pm
You're after gauge install, not audio ?
You could try Fastlane or Redline, see if they can give you some pricing.
www.redlineperformance.co.nz - Seaview in the Hutt, right next to Speedtech.
www.fastlanetyres.co.nz - Hopper St in Wellitown.
Ard Righ
Postby KiwiMR2 » Tue Jul 10, 2007 5:39 pm
Ard Righ wrote:You're after gauge install, not audio ?
Sweet....might e-mail fastlane, they sound pretty good :)
KiwiMR2
2003 Estima 3.0L
2000 Opa
KiwiMR2
Postby dvssky » Sun Jul 29, 2007 5:13 pm
http://www.redlineperformance.co.nz - Seaview in the Hutt, right next to Speedtech.
http://www.fastlanetyres.co.nz - Hopper St in Wellitown.
Arnt Redline And Andre/Speedtech the same? :?
2jz Altezza
dvssky
Postby ke70dx » Sun Jul 29, 2007 7:51 pm
They share the same building
ke70dx
Postby dvssky » Sun Jul 29, 2007 11:12 pm
ke70dx wrote:They share the same building
Andres showroom is a shrine to redline,isnt speedtech an official HKS dealer now ,through having ties with redline.confused :?
2jz Altezza
dvssky
Postby gepsk8 » Sun Aug 05, 2007 8:02 pm
do it urself remove pillar trim, add the pod for guages u brought earlier, tap a lighting wiring for gauges and earth or feed, wiring in sensors in, fit to gauges to pod, remount pillar trim.
gepsk8
Return to Wellington / Lower North Island Region
