KinLoud wrote:buy the adjustable - do it once, do it right - this way you can back it off if you find it a bit too tail happy.
It is possible to get the car so it is way too oversteery on corner entry under braking - take it in small steps from soft to hard to get the balance right!
4-AGE 4-LIFE wrote:The H/D adjustable rear bar for the AE corolla is a 20mm Bar with adjustment up to the equivalent of a 22mm Bar.
Or there is the adj bar 18mm adjustment up to the equivalent of a 20mm bar
AceSniper wrote:none s/s? so your front is 25mm? throw urethane in the front(s/s use 24mm)
20mm is very stable, you wouldn't lose it unless your purposely trying to flick it
AceSniper wrote:s/s run a 18mm rear so its a cheap upgrade on a non s/s car that has a 16mm, Or is it 14mm non s/s and 16mm s/s been so long since Iv touched that area.
But s/s rear is largest while non s/s front is largest
AceSniper wrote:supercheap do a bran "superpro" there corolla stuff can be matched over to ae101's... prolly the same shape as ae111's?
AceSniper wrote:4-AGE 4-LIFE wrote:The H/D adjustable rear bar for the AE corolla is a 20mm Bar with adjustment up to the equivalent of a 22mm Bar.
18mm adjusts to 22mm
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
