215W aftermarked Ecu
Postby Pirken » Mon Jul 09, 2007 12:42 am
Is there anybody that makes a ecu for the 215w engine ?
I have a manual not a tiptronic.
Here in Norway we only have 98 petrol so i have some degree of ignition banks. Need a after market ecu.
Have anybody made this switch ?
Should i go for the universal AEM ? or something else ?
I really want to go for a ecu that someone else have used so i can ask them question if something is going wrong.
Ty for your feedback !
Pirken
Postby TWSTD » Mon Jul 09, 2007 2:05 pm
I ran a greddy Emanage Ultimate in my ST215w 5 speed. There are many aftermarket ECUs you can use - if you want service and knowledge its often best to go with something familiar to those who wil be tuning it - ie what ECUs are avail in your local home town?
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
after marked ecu
Postby Pirken » Mon Jul 09, 2007 8:13 pm
My closes mapper uses AEM or the Power FC, I realy want a stand alone ecu not a piggyback. He asked me to ask "you" at the forum wats has been used at this car. Apexi tells me tha the Power FC cant be used for my car.
So i wonder, anybody used the AEM universal ecu ?
This is very expensive in norway 3 311,26 NZD.
Have a LHD Caldina 1999. And i love it !!
Pirken
Postby TWSTD » Mon Jul 09, 2007 8:42 pm
AEM is not a big brand in NZ - in fact there are hardly any resellers of AEM gear. For that price you are better to go with a Motec anyhow!
Here are some ECU manufacturers, most of which offer ECUs that will run the gen 3/4 3sgte engine (in no particular order):
http://www.motec.com.au/
http://www.linkecu.com/
http://www.autronic.com/
http://www.enginemanagement.com.au/cms/
http://www.wolfems.com.au/
http://www.haltech.com.au/
Click here!
TWSTD
Motec
Postby Pirken » Mon Jul 09, 2007 11:54 pm
Are you thinking of the M800 than ?
Pirken
Re: Motec
Postby fivebob » Tue Jul 10, 2007 12:02 am
Pirken wrote:Are you thinking of the M800 than ?
No need to go to the M800, the M400 will be ok.
m400
Postby Pirken » Tue Jul 10, 2007 3:30 am
M400 is even more expensive. in norway it kost 4 856,51 NZD with universal wire..
is this verry expensive ?
Pirken
Postby strx7 » Tue Jul 10, 2007 7:41 am
how much can you get a Haltech E8 for?
piggiback
Postby Pirken » Tue Jul 10, 2007 10:05 pm
The price on stand alone system is to expensive only for the petrol mapping.
so i wil go for the map ecu 2 instead.
And i wil have thise http://www.autosportwiring.com/index.html make the harness for it..
Pirken
Postby strx7 » Wed Jul 11, 2007 8:37 am
you need to be able to alter the ignition maps as well
Postby TWSTD » Wed Jul 11, 2007 11:12 am
Which you can do with the MAPECU2. Also has onboard electronic boost control, launch control and much much more:
http://www.drivenperformance.co.nz/scri ... roduct=860
We are agents for these in NZ, but our agency agreement prevents us from shipping overseas if there is an agent in your location already.
Click here!
TWSTD
mapping
Postby Pirken » Thu Jul 12, 2007 12:15 am
My mapper wil get me the ecu2, but you can mayby answer me on this.
Do the ecu2 start on scratch ? or does it start from the oem ecu data ?
Pirken
Postby TWSTD » Thu Jul 12, 2007 8:54 am
You need to build a fuel MAP - its not a turn key start. There are MAPS available for 3sgte (SW20 and ST205) though on the MAPECU2 website that are free to download here:
http://www.performancemotorresearch.co. ... ables.html
start with the ST205 one - it should be fine to get the car running (but remember these are just base maps - each individual engine is different so you WILL need a dyno tune).
Click here!
TWSTD
AEM F/IC
Postby Pirken » Sun Aug 05, 2007 2:44 am
I order the AEM F/IC and i wonder a couple of things .
My crank shaft position sensor and the cam position sensor have the same Ground, is this a problem ?
I just put the to ground together to the minus signal from crank/cam.
The Maf sensor should this be put on the Intake air temp or the Intake manifold temperature ?
or do the 3.5 gen 3sgte have a maf sensor ? or only Map sensor. if Map sensor should i use the output from the manifold pressure instead ?
And i can seem to find a signal ground on my pin list. i just grounded it to a ground signal from ecu.
I haven't mounted the o2 sensor yet because cant seem to find the type of resistor in any store here.
The engine starts just fine , but when reaching 3500 rpm it halts the ignition. but this it just fine before the mapping or ?
Pirken
need some help
Postby Pirken » Tue Aug 07, 2007 6:17 am
I tried to bypass first the signal from the MAP sensor.
same thing happened. fuel cut or ignition cut.
I tried to bypass crank and cam signal and only had the injector into the piggyback. but still same thing happens.
Anybody have a qlue was going on here ?
Pirken
Postby TWSTD » Tue Aug 07, 2007 8:16 am
I think you will find that noone in NZ usues AEM electronics - so you may be better asking on some US forums as they might have a better idea. I imagine AEM also offer some sort of after sales support via email or internet forum - try that avenue also.
Best of luck!
Click here!
TWSTD
Users browsing this forum: Bing [Bot], Google [Bot] and 18 guests
