1ggte head studs.
1ggte head studs.
Postby mjrstar » Thu Jul 12, 2007 8:16 am
are these re-usable, i'm building a fresh engine (without a manual) and hav not been able to find out weather these are a single use or re-usable. the torque settings do not state 'torque to yield' which leads be to believe i can re-use them.
Does anyone have the manual and cold check this for me. failing this the 4agze manual probably states the same process...
Thanks
Matt
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby thegreatestben » Thu Jul 12, 2007 11:00 am
I can have a look over the manual I have in .pdf
Can definatly give you 4agze specs give us a sec
1gge:
4agze:
Well neither of those list the head bolts as non reusable so hopefully thats enough for you.
Last edited by thegreatestben on Thu Jul 12, 2007 11:23 am, edited 1 time in total.
thegreatestben
Postby Mr Revhead » Thu Jul 12, 2007 11:07 am
are they torque to "x" setting or are they torque then 90 + 90
all toyota bolts that are torqued by degrees are plastic region
Postby thegreatestben » Thu Jul 12, 2007 11:35 am
P.s. fingers crossed you can read japanese :D
This is out of the 1ggte manual
thegreatestben
Postby mjrstar » Thu Jul 12, 2007 4:15 pm
um no i don't have the best understanding of japanese....... haha.
seriously though thanks for the info. i think i'll just run a tap down the holes and reuse them.
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby TRDGT4 » Thu Jul 12, 2007 4:17 pm
Mr Revhead wrote:are they torque to "x" setting or are they torque then 90 + 90
So don't reuse them.
TRDGT4
Postby tsoob » Thu Jul 12, 2007 6:01 pm
i dont think you can reuse them is they are strech bolts (have 90 degree rotation) when we did the head on mine we had to replace them and the my mates at the workshop checked with toyota and they told us to replace them.
tsoob
Postby mjrstar » Mon Jul 16, 2007 9:16 am
it appears int the manuals above that the 4age are torque to yield and the 1g is a straight torque. i think the ultimate would be to run head studs instead of the bolts.
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby Mr Revhead » Mon Jul 16, 2007 9:42 am
can you read the japanese?
if so, what does it say?
if not.... maybe it says otherwise.
Postby spencer » Mon Jul 16, 2007 12:46 pm
my 1gge spec page says just straight torque it up to 650kg-cm which is what that jappa manual is saying same as 1ge aswell
ms63 crown
spencer
Postby Mr Revhead » Mon Jul 16, 2007 12:48 pm
sweeet
i cant read japanese... :evil:
