strx7 wrote:Al wrote:E36 M3. The 3 litre one. You would be looking at a higher km one though.
cheaper, same if not more power and more reliable = get a 325i and put a worked 2JZGE with individual TB's on it. Same sound, toyota reliability, ease of parts, what more could you want?
Mmm, Boost wrote:Thats pretty high comp for a turbo that large...wonder if the idea was to try spool it quicker at the expense of out and out power.
Definately not what I'd use as a Targa car!
Mr Revhead wrote:[
thats your answer for everything
im suspecting you have a surplus of 2JZs your wanting to unload!
Mmm, Boost wrote:Yep, but its also gonna limit what kind of boost pressure you can run. A T78 isnt really gonna be all that efficient at 1 bar. I'd swap to something more like a GT3071 and have a far broader powerband.
Mr Revhead wrote:about 15-18 psi
strx7 wrote:Mr Revhead wrote:about 15-18 psi
?????? I didn't ask what boost they run. I asked what compression they run. But yeah they run that boost and as higher compression as they can with pump gas and that boost level, which is usually around 10:1 compression
only the Subarus.Mmm, Boost wrote:strx7 wrote:Mr Revhead wrote:about 15-18 psi
I was gonna, they're probably quite high. But then they also tend to be rebuilt quite frequently don't they?
strx7 wrote:Nah, I just think that the 2JZGE is such an overlooked engine. Find me another engine out there which can be readily purchased for under $1000 which with just bolt ons will happily take over 600HP at the flywheel reliably. (turbo'd of course)
